Saw #@Old Fella driving down Raymond Rd in Springwood this arvo; the family & I were having an icecream for my young blokes 6th birthday.
Mine was parked out front of RMS.
Hey mate! :wave:
Was it you Dale, that was parked on the side of the M4 last week having a snooze? :closedeyes: :closedeyes: :closedeyes:
Adelaide.. about 2pm. silver m35 blacked out tail lights heading towards the bay on anzac highway at morphett road lights and shortly after a white c34 s2 with dolphin grill diagonal road towards marion.
Edited by c34Florry
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
