Hi ya guys I t has taken me two years to get here and here it is, apexi power fc, apexi ax53b70 turbo, apexi induction kit, blitz lm spec intercooler, nismo fuel reg, nismo fuel pump, nismo injectors, nismo short shifter, nismo gear knob, trust oil cooler ,4 ' turbo back dump and exhaust(apexi), RB30 (japanese Spec) carillo h beam robs, ross pistons forged, total seal rings, balanced and blueprinted crank, n1 water [pump), n1 oil pump, ks cams, tomei valve springs, tomei valve guides port and polished heads, producing a lazy 386.7 rwkw? Im going porsche and ferrari hunting today!!!!!
  • Replies 50
yeah, what suspension mods have you done? any brake upgrades? what tryes u running?
awesome work on the car, but as Ronin said, if you can't get those ponies to the ground, you're going to be seeing a lo of Porsche and Ferrari tailights :D
that's a crazy power figure, nice work! :(
awesome work on the car, but as Ronin said, if you can't get those ponies to the ground, you're going to be seeing a lo of Porsche and Ferrari tailights :cheers:
that's a crazy power figure, nice work! :D
suspension mods are on the way, brake upgrades rta brake rotors ( as used on the v8 supercars) and ebc pads with stock calipers , they work ok for now.pirelli p zeros almost gone now!!!hahahaha
heyy nice ride.........
i have one stupid question..i know its stupid but im gonna ask it anyway.
Correct me if im wrong but why does your car have a series II front but a series I back?.....it doesnt look like the S1.5 either.........weird...hmmmmmz
but yeahh once again very nice ridE wit very nice power figures too!
I got a hunch someone along the line changed the headlights/front bar etc... it's just a hunch though.
ha ha very observant, a little old lady!!!haha reversed into my boot and yes she broke my trim, so instead of the white middle i got a series1 and ha it illuminated when the lights are on. :spcartman
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
