  • Replies 50
Hi ya guys I t has taken me two years to get here and here it is, apexi power fc, apexi ax53b70 turbo, apexi induction kit, blitz lm spec intercooler, nismo fuel reg, nismo fuel pump, nismo injectors, nismo short shifter, nismo gear knob, trust oil cooler ,4 ' turbo back dump and exhaust(apexi), RB30 (japanese Spec) carillo h beam robs, ross pistons forged, total seal rings, balanced and blueprinted crank, n1 water [pump), n1 oil pump, ks cams, tomei valve springs, tomei valve guides port and polished heads, producing a lazy 386.7 rwkw? Im going porsche and ferrari hunting today!!!!!
This is a funny post!
Bahhaha prank this should be in the wasteland/jokes section.
A true engine performance upgrade...
because everyone knows the RWKW performance gains of the %10 shorter than factory shifter & overpriced plastic gearknob!
Also i love your blueprinted crank!, but i dont know of many engine builders that will bother to blueprint just a specific engine compent such as just a crank or just rods or just rings (because that not blueprinting mate) blue printing is painstakeingly going over EVERY bearing/sleeve/ring/gaps etc. And perhapes buying 9-10 packs of rings & bearings and makeing sure all of them arel within +/- .001" of each other also + maybey $2-3K ontop of your engine build ... maybe you should understand what blueprinting means first and how REALLY BLODDY expensive it is to have done properly. (Ive included what it actualy means below, so next time you dribble rubbish on another forum they might just believe you? :kick: )
WHAT IS BLUEPRINTING?
Contrary to its name, blueprinting an engine has nothing to do with big rolls of paper that have strange, blue-colored drawings on them. Blueprinting an engine starts by designing it on paper first. Calculating things like compression ratio, piston pin (compression) height, displacement, and carburetor cfm requirements are all the beginnings of the true blueprinting process. From there it involves properly communicating your needs to the parts manufacturers and to your machinist and finally checking the parts, by hand, to ensure that they all meet your requirements.
Take a read, learn what you think your motor has, and stop dribbling dude.
:D
I think he delete a thread he post in SA section a while ago, tell everyone he own a 1000hp R34 Gtt and with a lot of mod
and he won't show us the car, cos he is not that "stupid" to drive it on the street and let cop defect him...
these aussie plates?
Yeah they are Aussie plates..squint a bit and you can see "SA" on the left
Those style plates were an option if you had 7 characters in SA I think?
@ Original poster: SHOT DOWN!
There is another thread started by the same user which I've already moved into the wasteland.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=58496
:headspin:
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
