  • Replies 47
you will get 15-20 rwkw difference with no tuning and you can up the boost to 16-17 psi without riskung ceramic in the cat. This combo with a good tune will get you 200rwkw. its a great upgrade.
I am in the middle of doing this right now. Today my friend managed to get the turbo off, and on. HOWEVER, the bend that bolts onto the compressor housing is different. I didnt get it when i bought the turbo which means finding one from the wrecker. But other than that its been a piece of pi55!
Will be interesting to see if it really makes 200rwkws. Thats pretty good power
Yes
No, :uhh:
The stock RB25 turbo wont handel much over 14psi for long periods of time. Before you put the exhaust wheel into the cat. If that doesnt happen the turbo will over spin and you will lose power.
Best safe efficency for a RB25 stock turbo would be around 10 - 12psi
Other than that.
Its fairly simple job, Just have to re-seal gasekts - If their still good other wise if their broken get new ones. Dont loose the copper washers for your water lines :) - you need 2 washers on each line.
:cheers:
Jun
Oh and does anyone else have the markings they can tell me on their turbo's? are they 45 V 4 just so i'm sure, coz i have to find the bend that comes off the compressor outlet from a wreckers and dont want to get something thats different. Help would be great thanks guys.
i was under the impression on an rb20 you could get away with running a little more boost due to the fact the turbo doesnt have to work as hard, filling only a 2ltr engine, and that you could run around 15psi kinda thing no problems ?
The ceramic delaminates due to the velocity at the point it meets the metal shaft.
example
the turbine produces 14psi at 100,000 rpm on the rb25, (lets call this point of stress)
then we devide 2500 by 5 20 get 2000 so we also devide 100,000 (shaft speed) by 5 fo get 80,000. So the shaft spins 20% slower to produce the same PSI.
So if you increase the shaft speed to 100,000 on the rb20 you will be spinning it at the same speed as the rb25 but producing around 15-17 PSI
See :D
These figures are used as an example and do not reflect the actual speeds of the shaft.
As the turbo has a larger compressor, It will produce more volume of air through the valves for a given PSI rating. (more airflow) at a lower temp because it is using less effort to generate the same volume.
In my experience you almost will not notice the difference in spool up time. plus the rb20 turbo drops off at around 6000rpm but the rb25 turb pulls hard all the way to redline!
:rave:
I've had an rb25 turbo on my r32 for a fair while now. I run it at 14psi with no probs. makes 180-190rwkw depending on the day.
As sombody mentioned earlier the only differance when putting it on is that bendy pipe that bolts onto the compressor won't fit the new turbo. I had to cut and shut with another peice from an earlier series rb20 to make it fit.
You will notice the power delivery is alot different to the stock turbo aswell, a little laggier but much more pull up top. Really goes well once its wound up. :whip:
straight turbo swap, depending on the boost u run, i would recommend a fuel pump anyway, saves hassles. Walboro intank pumps are my choice for mild setups anyway, fitted one to a mates cefiro with rb25det in it. Had to chop the wires and use connectors but that was not big deal
i just completed this swap last weekend, using a r34 gt-t turbo (nylon impeller, same as r33 s2 i think)
it came with the compressor outlet elbow so it was no biggy
findings are more power on less boost (2-3psi less) altho it is slightly laggier then i imagined, however this could be a tuning issue
top end is much better tho :)
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
