exactly... your no better than rob. At least my posts are all relavent and generally aid a discusssion or display my opinion on an issue... where yours such as this:
*poke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke
marty is cool
pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke poke poke poke poke pokepoke poke poke pokepoke poke poke pokepoke poke poke poke*
Now thats whoring
demonstrate your "whoringness
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
