Getting a bit self concious - I becomming a postwhore, jumpin all over the place and dropping a comment here and there. Some would say just a Ho, leaning on the post, in the garage on the washing machine....lol.
Question:
Do you get very hassled by the police when cruising around canberra in a group? I just dont need another run overr the pits. On a first name basis now out at dickson.
it more or less depends in where and when. if say we go out on a friday night to braddon when theres ****heads out there and the cops are out there then thered be a chance. now say if we went out for a cruise around the city on a sunday afternoon then out to the cotter for a BBQ then i dont think the cops would bother???
Hey Sinista, becoming a post whore are ya?? aiming for the jerry springer show? ....the title ? Secrets of a post whore,,,hehehehe, we could all appear in some form or another for ya, i am sure lycraman , spitter and madame lush and the arch nemesis, (bogan boy was it??, buggar - forgot!!!)would rise for the occasion....hahahahaa, oh its friday.......sorry Leigh, you can some to, but ur no longer pea shooter!.....nearly spamming again!!
"Hello my name is Patrick, A.K.A. DJ On Ice, in the forums...and well...oh this is so hard...I am a post whore!"
*CROWD BOO's*
"SHUT-UP! You don't know me!!!"
Yeah we need to get the swing back into our forums. :type:
Pat you crack me up heheh! *POKE* come on post whores where are you when I need you entertain me :D
*Walks In* *Hears of this Prime Possum fellow...*.....*KICKS PRIME POSSUM IN THE BUM*....*Find him self in jail*....INMATE:"What are you in here for?", PAT:"I kicked one of those guys in the Possum suits!", INMATE:"It's just so hard not to!"
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
