Yeh gus who do you think you are? always paying out on leigh and fellow 33's! sheesh! i cant believe you do this? HOW DO YOU SLEEP AT NIGHT!?!?! i believe you owe leigh an apology, cause that type of comment isnt fair, its galangaler! its not there fault there big boned! why be a bully for!? sometimes i really dont know about you angus. :(
Yeh gus who do you think you are? always paying out on leigh and fellow 33's! sheesh! i cant believe you do this? HOW DO YOU SLEEP AT NIGHT!?!?! i believe you owe leigh an apology, cause that type of comment isnt fair, its galangaler! its not there fault there big boned! why be a bully for!? sometimes i really dont know about you angus. :D
Beau dont try and use big words we know you arent that smart! :lol:
um I actually probably constitute about 1% as i pay out 33's as well, i drive one though so the jokes on me it seems lol.
soon enough my Daewoo will come and i'll be paying out all skylines because they won't have the quiet and smooth ride that only a Daewoo matiz can offer....*runs and vomits!*
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
