they call me big rec *uh-uh* big rec, ni**a i came here to drop it like its hot, who the boss ni**a who the mo**er fu**in' boss, whos the boss ni**a, now you know he fresh, this is how we scratch, this is how we do nobody do it like rectangle show me some love, when the rec's in the crib ma when can get dooown, put you back into it, cant keep tellin' me to speak about the rec, matter fact i dont wanna speak bout the rec, now loose it *bawawawawa* just loose it, ni**ga ask, ni**a i take you to the candy shop, ill let you lick the lollypop, ive been doin this since ni**a's be wipin, recognizing socks with the matching socks and so dont try'na run up in my ear talking all that raspry sh!t tryna ask me sh!t, goddamit, yo a hater, anyway breath, one into the two, two in to the three, three into the four, then you gotta breath, im steady tryna find the motive, why bring em out bring em out, times up wish the way i was livin could stop serving rocks Knowing the cops is hot when I'm on the block, And I, here comes the R to the E to the C, you should do me, ooh boy just touch my body i mean girl just touch my body, so go dj, what am a dj, shorty wanna ride wit me ride wit me, we can get eeh check im the boss i said, tilt my hat and i cross head, they say im so hood cause im so good dj's do not want me around cause sh!t might pop off and if sh!t pop off somebody's gonna get laid the f**k out, like like this, FRESH! werd.
No the L's rule won't work, Gus has his L's also (he's even driven my car)
wow thats game little gussy behind the wheel of a line... in future please be more responcible andrew and give everyone 3 days notice of when gus will be driving so we can make sure our cars are off the road :P j/ks gus good to see you young'ns can drive yourself around soon
