the only time u own me shaun is after someone else already beat you to it :D you just add the post: your getting owned every beau, in those exact words :D and leigh you know you love the wasteland, if you didnt why would you still be here? face it, we entertain you whilst you're bored
lol all of you are whores but in particular you, slide, gus and beau :mellow: so if i ever get admin powers which i wont i would watch out hehe
Simple Solution
GTFO of whoretown . :lol:
This is why this thread was created.
Really
Simple Solution
Really
yea but it spills over into normal threads you are pretty good slide but gus and beau are whores even outside of the designated whoring zones :D
you cant streak around here this is why i say we should ban gus and beau if they were over 18 we could have chicks stripping in here all the time ;)
i was gonna streak but i lost the moment...
now im just gonna wander through.... :)
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
