Since this is the wasteland i need to ask a random question
How come each tiem i try to change my avatar it always replaces it with the previous one? even if i remove the avatart completely and then wait a day and install a new one from a completely different computer it's still my old one..... it's shitting me to tears
leshy id start a thread in the support section, or pm a admin or someone, proberbly just a bug in the system
Thanks gus. turns out i just need a good old CTRL + F5 action. Also i think this version of firefox i have needs an update
Hmmm - Kiddie porn Signature. Is there an after market for that ?
I see Beau Ghetto neph is in Full damage control B)
I placed a call with the Kids Helpline :lol:
Edited by Sinista32
Shaun and Michael, Answers to your un-asked questions:
1) its not cartoon, its CG animation.
2) if it were cartoon, it would be anime.
3) if my Sig were kiddy porn then why are they fully clothed? unless you get off on the fact of teenagers clothed?
4) my Uncle was talking about Avatars not Sigs, and as you can see the person in my Avatar is far from "kiddy".
so how about that weather last night I know in the barton/forrest area it was very strange... the amount of successive lightning strikes was unbelievable they just kept cracking right overhead every 10 seconds or so. Also one must have hit literally 20 - 30 meters from our place scared the crap out of me :P
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
