I just had a martial arts lesson with an awesome dude named Richard Norton. He's been in a few movies with Jackie Chan and Chuck Norris and does all kinds of other cool stuff. Learnt so much, so don't cross me in a dark alley anymore, or else I'll have to try and remember what he taught me.
Anywho, it was cool, i have bruises, yeah.
Anyone know where I can pick up a ring and piston set cheap (as in not $300 from ACTION MOTO) its for a DT200R 95 which has the wr200 in them I think.
Need to replace the old girls heart its a bit well pitted at best lol.
Thanks
Damn all you pubes although like amaru said it keeps people like me employed :ninja: I have never actually worked for the PS i had the opportunity a couple of times but i seem to always just move to another private company... go figure
lol baconer that is pretty funny more so because of the replies to the movie and how it's racist and then people calling each other crackers etc... crackers funniest word ever.
Posted in the SAU wasteland:
http://www.youtube.com/watch?v=rGrqW3nx5HM
holy crap... hahaha
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
