today is my birthday. anyone who does not wish me a happy birthday will be banned.
Shell :)
HAPPY BIRTHDAY SHELLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLYYYYYYYYYYYYYYYYYY hope your day was not to bad and got the chance to have a few brewski's :rant:
Cheers,
Leigh
I dude at work got a Toyota GT4 and it got a water to air intercooler do any other cars have this seems a bit stupid
Older Liberty's have em, many AM companies sell em. Popular in rota drag circles, and with horsepower dyno queens.
Why you say stupid? They have their place for sure. Can keep intake tracks a lot shorter; improve throttle response etc, then mount the radiators for it where ever you want.
The setup has a buffer too, so you don't get the same level of heat soak, that air->air IC has in stand still traffic.
Happy BirthDay Shell :rant:
Also, memo to leigh, quotes are supposed to go before posts.
i always do it that way in PM's, but not on the forum... dunno why :rant:
thanks leigh & michael :)
I had a fantastic day, much better than last years birthday which sucked.
and yes leigh I've managed a couple of bevvies :)
Happy BirthDay Shell :thumbsup:
I was just think that a contain of water sitting on top of the engine is i dont know like a rice cooker , what about when it is full cold do air to air work better
Hey Rick444 I'm with you re gettin out of that workshop .... but I am interested, does the intercooler on a stock 33 make a big difference? I'm not racing, drifting, draging etc - but am interested, is it a worthwhile thing to do?
It doesn't really make a huge difference, but my car feels better after putting it on, more responsive..it's hard to explain...
I would say it's definitely worth it, especially if you're planning to do more mods. :thumbsup:
HAPPY BELATED BIRTHDAY SHELL!!
BTW, it would be nice if crime took a day off. Imagine if you could leave your car unlocked and go shopping and come back to an untainted car: nothing stolen and no scratches/damage.
Ha Ha as if that could ever happen.
Put the crack pipe down :P
Magine a box welded around a normal air->air IC, and then water pumped through that box, through and around the fins, and then to a radiator(s) [ Separate to the engine radiator clearly]
Your just replacing the air that was moving through the air->air cooler fins, absorbing heat, with water... which then releases its heat to the air, when it gets to the little radiators
haha there was no intension of that leigh, which is lucky cause shes pretty much a grandma :domokun:
pretty weird, only 3 movies ive been keen to see recently (300, spiderman 3 and 28 weeks later) are all ones youve posted about skylvia. Do they tell you anything about the main characters from the first one in the new one (james and selena?)
Edited by Baconer
havent seen spiderman 3... i heard its a tad dissapointing...
Nah nothing about the original 2, but it starts at the 28 days later timeline, then shows how it progressed through to 28 weeks later. much better than the 1st IMO. the 1st one was still good tho
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
