Anne Hathaway?
http://www.dougweb.org/images/blog/AnneHathaway-0001.jpg
http://static.flickr.com/54/176070014_fa7408f7a2.jpg
http://img142.imageshack.us/img142/9373/anne001bc7.jpg
Dood, i dun givaphuk, im calling every X Chromosome packing human i know, to go watch this. I can play handbag for Anne any day :thumbsup:
i was gonna head out, but ive never been to wakefield and dont know how to get there, i asked if people were cruising but didnt get a response... ohwell...
On another note, anyone here heard of the band Red Jumpsuit Apparatus?
Just heard one of there songs yesterday and really liked it, its called face down. awesome song.
is there album worth obtaining? or do they not have many good songs?
Well I just bought a house WOOHHHHHHHHHH on really short notice too noticed it this morning and signed the contract a few hours ago. I can't believe it this feels much better than when we got the apartment. House needs a fair bit of work but it's all superficial so I think we got a bargain WOHHHHHHHHHHHhhhhhhhhhhhhhhhhhhhhhhhhhh
To all out there looking for house bargains they do come up but they are fairly rare and you have to be willing to move straight away. I had to ask to see the property this afternoon even though it was not open (he agreed) and had a look and went wow this is tops signed the contract and handed him a 5% deposit. Another guy was meant to arrive at the same time to check it out instead he arrived an hour late. He put an offer down of $5000 more but was turned down as we had already signed the contract.
So my home buyer tips
1 – Have your finances in order (Deposit, pre-approval)
2 – If it does look to good to be true, make sure you read the building report/pest inspection and if it checks out move quickly as it will be sold probably within a day or two of being listed.
3 – Make sure you have already spoken to a solicitor so you know that things can be moved quickly if required (this almost caught us out)
4 – Be confident and up front with the real estate agent tell it like it is if you want it and think you may get stooged put a full price offer down and insist on transferring contracts as we only beat another couple who put an offer in first as they offered $3000 less than the asking price (what stooges) and then again as mentioned above as they arrived an hour late (missing out on a bargin because you were an hour late damn...)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
