only have to give a refund if it is faulty within 21 days of purchase...after that it is either replacement or repair...depending on the warranty provided by the company...so a small appliance that has say a 1 year warranty....if it breaks within 21 days then the customer can have a refund. after 21 days...swapover or store credit...
something like a washing machine, tv...espensive stuff.....after 21 days it is repair...through the service agent.
all depends on the warranty provided by the company as to whether its in store replacement....or repair...
also depending how we feel we may take some stuff back after 21 days if we know we can get our money back from the company....but depends on the customers attitude and how i or whoever else feels.
yeah that's what I meant pretty much - "out of the box" faulty
On a similar note, I know someone at the moment who bought a fridge from Harvey Norman and it arrived with dents. They've refused to compensate her (ie. in the same way you'd normally get a pretty good discount if you bought a "scratch and dent" whitegood). They've only said that they'll replace the fridge but they have none in stock and and a new one could take weeks or months and in the meantime she's not allowed to keep the dented one. So she would have to go with no fridge :(
Moral of the story, Harvey Norman are wankers :)
yeah ive heard alot of bad stories from harveys. customers complaining about them not having items in stock...not being able to buy across departments (eg buy a computer and a fridge at the same time) etc etc etc.
your friend...i would say her best bet would be to try get a swapover and chose another...i figure she probly wouldn't wana but if she needs a fridge then she needs a fridge. usually a order should only take max of two weeks so yeah.
in terms of being compensated with a discount or something...thats understandable that they wont...but weeks or months is a bit of a joke.
yeah a DOA is a refund. Slightly damaged anything should be heavy discount. A faulty one should be Repair or Replace.
Buy a slushie when you want one - screw buying a spesh machine. Oh! you can get burboun ones at the Nats. How bout a Magic Bullet on high if you really want home made.
Have I cross threaded here?? Slushie or fridge...cant remember....
Edited by Sinista32
sin mate I am sure we can buy a cheap one, use it for JD sulshies then give it back, just dont tell them about the DJ that went through it
I JD slushied about 3am :P
I dont want to here the word slushie for the rest of today!!!
I watched a game of Slamball at the club this week (I think it was Fox) and it was great to watch. I would like to see more of it, especially the faceoffs where they smash their opponent into the hoop board (Im certain there is a correct word for that board, but I'm a netballer and don't know much about basketball)
http://au.youtube.com/watch?v=k4DX4re0AEw
Thats' very cool indeed. I think we in the ACT could manage somethin BIG!!!
It's very cool driving with heaps of lines. Checking out the cars and chatting with the owners. There is so many lines in Canberra that aren't on SAU.
I'd like to do a bit of OZ.
EDIT: If there is 2 or 3 others that could get a few weeks (2-4) off in late Feb early March 09 :D
Edited by Sinista32
Best contact sport ever :D
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
