Chances are they mean the grab point is higher then usual which can mean the clutch is wearing out.
Have you noticed the friction point on the clutch has changed?
Ahh yes. That makes sense. Thank u
wish they were phased out in Kambah.
I expect the good ol (VR, VS & VT) commy will be the choice of lowlife for many a decade to pass..........
and a fair few Magna's
I say we destroy the nest :P
Edited to add models
I have a "Warn Status" bar but I dont see one under your Avatars
am I being picked on ? :P
Kyle :thumbsup:
I'm working from home all day tomoz if your out this way
not sure when my GTR will be released.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
