want to get membership bar
Print it off, Fill it in, Scan it and email it to Shell :yes:
Doooo eeeeeeet!
As Sin said, print it, fill it, scan it (probably should pay it too) & Email Shell or PM her with it.
PM worked for me!
Suddenly I feel like I belong...
If you need one get on to this quickly. Save yourself about $10k
It is back up for sale team !!!
http://www.skylinesaustralia.com/forums/topic/414545-nismo-fine-spec-engine-and-other-parts-to-suit-gtr-3332/page__st__20
Engine reduced to $13500
For sale is a brand new nismo fine spec engine.
Specifications-
- N1 Cylinder block
- N1 Component / nur spec pistons
- N1 Component precise friction piston rings
- Nur spec connecting rods (Balanced)
- Nismo F112 connecting rod bearings
- Nismo F112 main bearings
- Standard spec camshaft
- N1 water pump
- N1 oil pump
- Nismo timing belt
- Nismo metal head gasket (1.2mm)
- Nismo oil pan baffle plate
- Nismo fine spec 2009 special edition rocker cover ornament
- Exclusive fine spec 2009 special edition engine plate
- Front differential (Gear ratio 4.11)
- Black cylinder head covers
This engine is located in Perth WA and can be shipped anywhere in Australia at buyers exspense. I am asking $15000.00 ono for the engine. This is a rare piece of nismo excellence.
post-86144-0-61836200-1353993224_thumb.jpgpost-86144-0-71613300-1353995116_thumb.jpgpost-86144-0-36585700-1353995140_thumb.jpgpost-86144-0-71337200-1353995170_thumb.jpgpost-86144-0-12130000-1353995189_thumb.jpgpost-86144-0-17501300-1353995217_thumb.jpgpost-86144-0-97843600-1353995247_thumb.jpg
I've noticed that for the 20yrs I've been alive I've never posted a letter.want to get membership bar but posting letters seems so ancient to me and I keep procrastinating.
Drop it into Wanniassa PO in person if you're scared of posting your first letter :D
Big thanks to Rob for the feature Photo of Sinista in Capital Magazine :thumbsup: (available at all quality newsagents)
You know I wouldn't have minded being photo chopped with bigger guns and a sixer :rolleyes:
Cheers Mate
:cheers:
We used to print that! Why was it in there? Was there an article with it?
What's more preferable scanned email or post document.
It really doesn't matter - scanned is quicker though as I check the PO box about once a week. But whatever's easiest for you.
Nah, pop that snail mail cherry, it'll be invigorating!!!
:laugh:
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
