Ditch the stuff you know will spend the next 5 years rusting in your backyard.
Only bring whats worth bringing home.
Oh, dont forget to keep bits to pass ACT rego.
Edited by D.I.Y. Mik
Coooool, sounds like a good un. Cant wait too see it.
Im booked in for a fix up and tune on the 27th so hopefully be all sweet by the friday.
When do you think youll have it on the road? As in coming to meets etc.
Pick up should be in 2 weeks, first Friday - long weekend Friday will be at the meet.
You're gay Bren :(
I am as straight as they come buddy unlike yourself being as bent as your car....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
