Anyone else Notice it has 2 BOVs ??? Why? Sell the Trumpet and keep the Stocker... or buy a GTR BOV off me... I'll even install it for you.
# --- Looks Many Nice J Dawg. :thumbsup:
Stocked is attached - aftermarket is unattached. GTR BOV you say? Define :)
The pipe the aftermarket bov is attached to will need blocking off (if you remove the trumpet) or replacing... I have a spare... :whistling:
GTR BOV is bigger and sounds cooler... I am using one with my pod and Metal intake... It Sounds very cool.
Haha! Does help fitting come with the purchase? ;)
Excuse me while I apply Palm to Face...
Appears the ACT is going the no Turbo (Performance cars) for P laters as per other states
Will be goo in the sense that us full licence holders in our performance cars can stick it to them in their Barina's lol.
  • Like 1
The dumbest P plater rule ever is only allowing them to do 80km/h on the highway. On my last trip up the Hume a couple of weeks ago, there was shitloads of them, and it really f**ks with the flow of traffic to suddenly come up on someone doing 80 when you're all doing 120. Especially when trucks and shit are trying to overtake them at a slower speed than the rest of us!
Edit: just looked it up and it's 90... but I swear they were all doing closer to 80 lol
Haha! Whose laughing now? you young, disrespectful, Know nothing, know it all, think you're invinsible, Tunnel visioned little C#%ts. Huh?? Who?
Uh huh. :yes: That's Right! The Old Farts... :rofl:
Sukdintoem
The NSW P/L speed restrictions are f**king stupid. They become an obstruction to traffic and in turn could potentially cause accidents by OBEYING THE LAW.
If the argument of them being too inexperienced at that stage to adhere to the 100/110kph limit, then logic would suggest they shouldn't be driving at all! Obviously this isn't the case, so why hold them back? f**king clowns lol
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
