Personally I don't
Brand spankers - $4000 without rubber. If you can locate newies.
Every so often they will do a run if the numbers are there.
I bought my 18 x 9.5 +12's for $4k last year.
Ones above have been resprayed.
You would need to see each one to check for gutter rash
no longer have the original Nismo stickers
the front one looks concave and the one in the back looks different (maybe optical illusion)
I think you can do better.
There was a silvers set up for sale recently that I believe is cheaper (if not sold). To suit GTT offset
Edited by Sinista32
how f**king poorly do your gutters deal with a bit of rain? Lakes everywhere tonight!
Probly a combo of not much rain lately (so not soaking in well yet) and all the leaves having fallen off and blocking things up.
I went through a puddle this arvo that would've been a good 15 meters long, trying to drag me into the gutter. (left side only).
Fight it and floor it. :D
  • Like 1
So, I have been invited by family to attend a "track day". To bring our cars out and "race" them around the track. Now, since this is a invite I can reject or decline - my main concerns are if I bring my car to the track I risk blowing something (Rosie is my daily). Once you see the line up - you'll soon discover an easy option for "you got no chance", however, since it's family it's more a fun thing and bringing the performance cars out in the family. Once you see the line up - you'll know I'm the baby out of the 4.
So the lineup for the day:
Uncle #1 Holden Monaro CV8-Z
His son; cousin - RX7 - Bathurst addition.
Uncle #2 Porsche 911 Turbo.
adv7.1_automotive_connoisseur_adv1_wheel
Me: R34 GTT
So yeah, no chance at all for me to even compete but I'd like to go out there and have a fun day,
but is it worth risking a breakage? (Are track days amazingly fun that even if you break something you're still on a high etc)
Do many things break when taking your car around a track?
anything I can do to prepare Rosie for as safe as possible run?
How many lap should I do before I start to retire the old lady?
lol who?
firstly you can beat all of them (except probably the porker), especially if you can borrow a set of semi slicks :)
seriously though....assuming the car is in good condition, do an oil change, have the brakes bled and keep the boost turned down, you'll have a ball.
I ran my old gtst (standard boost) at track days for years without any mechanical issues. Its only when you modify them that you have troubles.
# of laps are easy...keep going until the brakes fade or the water starts to get hot :)
  • Like 1
I don't know the RX-7 is twin turb AWD and the Monaro.. well I dunno - maybe in the corners :P
Anyways - semi slicks is a nice idea :) Sounds as if Rosie is going to live through it if I decide to go down. Boost is set to 10 PSI (low enough i hope) and everything else seems fine - might do a a quick service before I "track" ;) down. Thanks for the tips :)
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
