Are we not men, NO we are devo.... D E V O
Big lulz :D
Crack that whip
Give the past the slip
Step on a crack
Break your momma's back
When a problem comes along
You must whip it
Before the cream sits out too long
You must whip it
When something's going wrong
You must whip it
Now whip it
Into shape
Shape it up
Get straight
Go forward
Move ahead
Try to detect it
It's not too late
To whip it
Into shape
Shape it up
Get straight
Go forward
Move ahead
Try to detect it
It's not too late
To whip it
Whip it good
Edited by Sinista32
Freedom of Choice by DEVO
A victim of collision on the open sea
Nobody ever said that life was free
Sank, swam, go down with the ship
But use your freedom of choice
I'll say it again in the land of the free
Use your freedom of choice
Your freedom of choice
In ancient rome there was a poem
About a dog who found two bones
He picked at one
He licked the other
He went in circles
He dropped dead
Freedom of choice
Is what you got
Freedom of choice!
Then if you got it you don't want it
Seems to be the rule of thumb
Don't be tricked by what you see
You got two ways to go
Freedom of choice
Freedom of choice
Is what you got
Freedom of choice!
In ancient rome
There was a poem
About a dog
Who found two bones
He picked at one
He licked the other
He went in circles
He dropped dead
Freedom of choice
Is what you got
Freedom from choice
Is what you want
(repeat)
(think it was this song, in the clip, had a Baby? sticking a knife or fork in a toaster...) :wacko:
DEVO = 2 Hits. :(
Edit* actually 3. She's just the girl, she's just the girl, the Girl you want...
and they did a weird version of The Rolling Stones' "Satisfaction" too.
ahhh... memories.
fidelia100
Apparently i have a love interest in SAU:
(Greeting From Fidelia),
How are you today? and how about your health? hope fine and you are doing well, My Name Is Miss Fidelia, I am looking for a very nice man of love, caring, honest, matured, understanding, and of good character, then after going to your profile on this site (www.skylinesaustralia.com)i pick interest in you, so i will like you to write me with my E-mail address which is as follow, for me to tell you more about me, and as well give you my pictures because am really looking for a serious relationship with you.Remember that age,distance,colour,language,or religion doesn't matter,but true love does.My address is( [email protected] ).
thanks Yours New Friend
Miss Fidelia.
:wub::ban:
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
