bluebirds are cool, esp the weird jap models. But then I like pulsars too. actually I like pretty much everything Nissan has ever built; except tiida of course there was no redeeming feature in that car.
zeb are you coming back to the world of cool? I'd be a bit worried about this, sounds they modified it all the time "Last Modified 15/07/2013"
Before I bought the first one (White), I test drove an Auto SSS Attesa Awd Turbo SR20. It was Quite amazing. :woot:
I personally have nothing against Pulsars other than they're like assholes, Everyone Has one!
and WTF was the whole Tiida thing anyway? and now the Pulsar is back! :wacko: but the newies are nice. Big but nice.
dumb f**king nissrenault idea. kind of like the m35 :rofl2:
I don't know of any good gtrs for sale, although I do know where to get an excellent cube.
honestly, if you are not in a rush you can just never beat importing yourself for value. even with the yen off 10% from 3 months ago when I bought the cima, it is still soooo cheap for what you get
haha I want the march too. it's been off the road too long but it is still not next off the blocks
1. get ute out of garage
2. get race car running....needs clutch unwelded from flywheel and an engine swap (current one runs great but has crack in block near water pump that needs welding)
3. get stagea reverse lights and knock sensors working...it has some electrical challenges from the rb30 swap
4. finish march motor and get it running again
too many projects
A tidy GTR you seek?
http://www.carsales.com.au/private/details/Nissan-Skyline-2002/SSE-AD-2046295/?Cr=1&sdmvc=1
There we go ! :P
ahh farking internet knows everything! I thought that feature was broken. It's really just a reminder I am getting too damn old (and grumpy)
Anyway, thanks :) ....and now off to dinner
Bahahaha!!
I never even look usually, saw it by accident :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
