NSW are now allowing P-Platers to drive Turbocharged cars.
Link: http://smh.drive.com.au/motor-news/nsw-backflips-on-pplate-turbo-ban-20130807-2rg9o.html
NSW is set to overturn a ban preventing P-platers from driving the latest turbocharged fuel efficient vehicles.
Provisional drivers in NSW will be subject to fairer vehicle guidelines from next year, with the state government due to adopt a national framework that better reflects vehicle performance.
Under changes to be rolled out as early as January, a contentious blanket ban on turbocharged and supercharged vehicles will be replaced by a formula that calculates the power-to-weight ratio of a car with a limit of 130kW/tonne, opening up a plethora of low-powered vehicles for P-platers that use turbo-chargers to save fuel
Yeah not sure. Each state as their own road laws so it wouldn't suprise me that it's at a state level.I wonder if it is for new cars using that formula or if it'll be for older cars as well.
I wonder if that would include something like an XT Forester. I was driving one on my P's and legally should not have been, but never got a second look by police.
It raises an interesting point though. The XT engine etc. is the same as the WRX's and in some cases bigger displacement and turbo depending on the year of WRX.
I always wonder why driver education is not taught in school prior to being of age for a licence.
In the US they have driver ed in schools, have done for a very long time. It used to include a trip to hospital to visit people seriously injured in car accidents etc. as well as driver training.
I always wondered that too cause I think that'd be an awesome idea.
my school did that.
Without subsidies on offer, these programs are only ever attended by INTELLIGENT members of the driving community - which unfortunately make up such a ridiculously small percentage of the 'problem' drivers, since those drivers are simply complete morons haha
  • Like 1
When i had my first car, id see the bloodstained wrecks at the wreckers as i was getting parts.
Some had bits of skin and hair :sick:
flamin mongrel!!! It certainly idles and revs over 2500rpm but I haven't driven it yet...
and actually no. Despite the fact my bonnet is currently open and has been all day, I've only been fiddling in the boot and mostly the passengers footwell. :) was under Rosie's Bonnet though.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
