Stupid rain. As long as I feel well enough to go get some Brodburger tomorrow! :D
Bahahaha so close!! http://canberratimes.drive.com.au/motor-news/man-caught-selling-fake-lamborghini-in-china-20130920-2u3yl.html
  • Like 1
I'm heading back and forward each week if you want me to drop it off to them
You know them i spose?
Sydneys a big place, as long as its not going out of your way.... that would be awesome!
When do you go back?
I hope you have those Aloe tissues. Bit stinky but sooo much nicer on the nose and much less of the red raw rash. :/
Yeah I wish I did :( When I venture out of the house (which won't be today) I'll get some. They're great!
pm sent Mik.
Shell...sounds like man flu. harden up.
Hey, see how I'm not even calling it a flu? Just a mere cold. Don't have to exaggerate my illness like males.... ohhhhh I have a sniffle, must be the flu! No, if it was the flu, you wouldn't be moving :P
Copped some mad road rage.
Had some bloke tailgate me and then try ram my car off the road tonight.
He got in front of me and slammed his brakes on until we came to a complete stop. I was scared shitless and smashed it in first gear and took off. Didn't want to break the speed limit so he caught up fairly quickly and tried multiple times to ram me off the road. At one stage I was driving on the medium strip trying to make sure he didn't hit my car.
I think I may have cut him off when I pulled out to overtake, first I knew of it was when he pulled up beside me and started yelling.
Couldn't even call the police because he was trying to ram the car and I didn't want to take my eyes off the road.
I ended up darting off on one of the exits along tuggers park way at the last minute so he couldn't follow. Didn't get his number plate either because I was so scared.
One hint is that PayPal will ALWAYS address you by your full name.
Also there was no chance I was going to pull over. The guy looked like a lunatic and I could see him being extremely aggressive.
I reported it to the police just in case someone else noticed the incident and reported it.
That is Farqued! What kind of car was he in?
Must've been Hatin' on the old Series 1. :P
I had a guy years ago pull up in front of me and get out with a Beer Bottle in his hand.
Reckoned I flew up his arse like an Eagle. He was pissed by both definitions.
Luckily I somehow talked him down... Kents are Scarey.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
