Just saw your photos
That car looks hawt as fark!
Ahhh I can't decide on white or red
or Silver or Black.
Richard's is Gorgeous and Elle34's Black one is Very SexXxy.
Red is supposed to be Fast!
But clearly it's Not. :laugh:
Talk it up while you still can m8. You won't be able to for much longer !!!!
Only reason why I am going 250kW is to put you behind me ! I will even get a special sticker saying "Sup Rob" and then another "2" to show you what place you're coming ;)
now now M8. Don't make the GTRs of Canberra put you in your place.
Haha it's either Red or White sorry guys
Not going black again because it always looks dirty and I'm over cleaning.
This is why I want to go red
http://www.skylinesaustralia.com/forums/topic/383498-my-bnr34-vspec-uk-model-in-germany/
Well now that you mention it, I could sell my R34 GTT and buy a R32 GTR with some spare change. Hmm what to do, what to do !
Lol!
I would hate to see the quality of 32GTR you would get for your 34 with spare change.
They're very expensive for a good one
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
