Where is there a camera in a 50 zone?
It was in the burbs. It was facing South as I was driving South. Went up a hill and I'm guessing it took the picture as I was driving up the hill (Ass shot haha)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
