Thanks guys.
Great day, not many laps because there was 57 entries.
But heaps of awesome cars to see.
Lap times here: http://sdma.heliohost.org/WebDisplayBoard.php
Some cars:
post-89755-0-04993200-1382252276_thumb.jpgpost-89755-0-89002900-1382252293_thumb.jpgpost-89755-0-71321700-1382252308_thumb.jpgpost-89755-0-20476600-1382252327_thumb.jpgpost-89755-0-49553800-1382252347_thumb.jpgpost-89755-0-95785800-1382252369_thumb.jpgpost-89755-0-90906000-1382252393_thumb.jpgpost-89755-0-11241400-1382252421_thumb.jpgpost-89755-0-57147100-1382252448_thumb.jpg
And Rob is a fkn legend, any who dispute this are FOOLS! :D
Pretty good, the diff works great and the tyres are pretty good too.
Some understeer, but i dunno if its the car or me, as it was only a couple of times.
And my best lap had a big mistake at the first corner, stuffing the second and third cos the first 3 are real close.
With calmer driving i should be able to get under 50 seconds easy.
So Proud of Mik our DIY Guy. Great improvement.
The recent mods allowed changing into 3rd gear up the hill which meant more speed / Better times.
Will be even better next time mate! Goodonya! :thumbsup:
post-78856-0-12423600-1382252849_thumb.jpg post-78856-0-29013600-1382252852_thumb.jpg post-78856-0-42710000-1382252856_thumb.jpg post-78856-0-98555300-1382252859_thumb.jpg post-78856-0-26416600-1382252862_thumb.jpg post-78856-0-61671000-1382252865_thumb.jpg post-78856-0-21893200-1382252868_thumb.jpg post-78856-0-53161200-1382252870_thumb.jpg post-78856-0-14526300-1382252874_thumb.jpg post-78856-0-87400200-1382253744_thumb.jpg post-78856-0-99720200-1382253748_thumb.jpg post-78856-0-29625000-1382253742_thumb.jpg post-78856-0-88398700-1382253225_thumb.jpg post-78856-0-00235300-1382253229_thumb.jpg post-78856-0-59988400-1382253221_thumb.jpg
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
