Seriously don't think so Shell. It's not like it's plugged into socket.
It will be hard wired and terminated in box on the oven. Definitely an electrician required.
If you managed to find someone not qualified then the sleepless nights worrying about it and the possibility of something grave happening.
Call in a qualified electrician :thumbsup:
Edited by Sinista32
Some have plugs.
And the ones that dont are hard wired.
Youd be pretty game just to touch it, what if you didnt turn off the power properly?
Elecricity- cant smell it, cant hear it, cant see it, when you feel it, your fried.
Ah ok, thanks guys. Just thought I could avoid having to call out an electrician twice. Was definitely going to call one to install new one.
And yeah I would have turned the mains off completely!
You should be fine to got to the outside fuse box and switch it off...
I'm fairly sure it has to have its own circuit breaker by law because its hard wired.
But if you feel safer turn them all off
Bloody Pat! Did you know that him and Nicole got married?
It's ok, I will just suck it up and pay whatever needs paying.... just thought disconnecting might be easy.
I really need to actually advertise my car for sale so I can afford all this stuff lol
You wanna live with him but you wouldn't live with me... :( flamin mongrel!
A new house in Casey might just have a Kitchen made by my work as we have done many in Casey.
If so, my fingerprints will be all over it. :ninja:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
