Seriously don't think so Shell. It's not like it's plugged into socket.
It will be hard wired and terminated in box on the oven. Definitely an electrician required.
If you managed to find someone not qualified then the sleepless nights worrying about it and the possibility of something grave happening.
Call in a qualified electrician :thumbsup:
Edited by Sinista32
Some have plugs.
And the ones that dont are hard wired.
Youd be pretty game just to touch it, what if you didnt turn off the power properly?
Elecricity- cant smell it, cant hear it, cant see it, when you feel it, your fried.
Ah ok, thanks guys. Just thought I could avoid having to call out an electrician twice. Was definitely going to call one to install new one.
And yeah I would have turned the mains off completely!
You should be fine to got to the outside fuse box and switch it off...
I'm fairly sure it has to have its own circuit breaker by law because its hard wired.
But if you feel safer turn them all off
Bloody Pat! Did you know that him and Nicole got married?
It's ok, I will just suck it up and pay whatever needs paying.... just thought disconnecting might be easy.
I really need to actually advertise my car for sale so I can afford all this stuff lol
You wanna live with him but you wouldn't live with me... :( flamin mongrel!
A new house in Casey might just have a Kitchen made by my work as we have done many in Casey.
If so, my fingerprints will be all over it. :ninja:
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
