Found it again.........
This is a good example of how some machines can become more than just a machine.
And you can dance in the sky.........
viva la France
Mik have you ever thought of joining the airforce I think you'd love it.
Aviation is fairly popular in my family, ive flown a cessna and a paraglider, my dads been in the industry doing r&d, my uncle is totally nuts for aircraft.
Always wanted to be a pilot, but by 14 i was too tall to fly a fighter.
Normal aircraft are a bit of a squeeze.
And life....... you know how it goes.
Id like to build some fpv rc jets, but the terrorist paranoia laws make it illegal.
It would be an affordable way to fly like those Mirages.
Almost the same thing with dad - he wanted to fly but got glasses at the age of 16. So he became a Chaplain in the Airforce instead.
We Were Soldier - Too Tall haha Might of been able to fly helicopters? :O
My step brother in law (:/) was in the army and his vehicle hit an IED, which forced him out so he joined the air force.
Something to do with his army injuries means he cant be the pilot (he was super bummed about) but he is the guy that sits behind the pilot of a fighter plane, like Goose, a navigator is it called?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
