Rebuilt my PC. Pulled it apart, cleaned everything and put it back together. Also put a new CPU cooler in and Overclocked the FK out of it. Result: what feels like a brand new PC! (It's 4 years old)
When I get back can you help me OC my pc
got myself an i7 3770k
Yeah no worries Dan. It's pretty simple. Did you get a decent cooler for it?
That will have to be the first thing I do when I get back. Right now it's just running a stock cooler.
My GPU is a HD7950 I believe, might even purchase another one depending on how much money I save while over here.
An SSD is probably on the cards as well.
This is currently the best value cooler on the market and is ranked 3rd for air coolers. It is the only one worth buying unless you want to water cool your PC. If you have not got an ssd I do highly suggest one. Is the 7950 a 3gb card? If so that is still overkill. I run bf4 on ulta with my old gtx570.
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18670&cPath=23
Happy belated Bithday Shell!
I never knew why shell reduces the content blend in winter. It s because its so hard to start the car when you're at 85%. So when to the servo bought a gallon of 98 o dilute the E85. It started on the first go this morning with ice all over
I'm sure some of you guys have heard of Nigel Petrie and or seen his drift Hilux. Very well put together doco showing his passion and his commitment to what he loves. Great stuff!
http://vimeo.com/93566294
Wow! Awesome Watch.
If that doesn't inspire anyone to turn a spanner then nothing will.
(got the day off today) :D
Gonna turn me a spanner.
I'm sure many of us would love to achieve that moment where no screw or bolt is to much for the mechanical mind ! What he has is a chronic passion - beautiful thing to see.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
