Yes, its doing nothing, but gathering dust and rust.
Cant find my camera cord to show you, but it is the one you gave me.
I wasnt using it, or planning to, so i dont need a replacement.
Ill drop it off, good excuse for a drive.
Went out to the cotter and Brindabella rd the other day, nice drive.
I wonder if roads are bumpier than they used to be or if its just me. Because i find going fast is not good at all, but 20 years ago i could go WAY faster and not feel like im about to be thrown off the road.
And i dont think its my car as ive had far worse shtboxes going faster than the Skyline.
Ps..... dropped it off. ;) I forgot which one, but the blonde told me. :yes:
Went for a drive, my car is fun to drive now.
Saw a bunch of guys on minibikes cruising down Belconnen way. I noticed they were all very nice looking bikes, ( original Honda's ) and the riders had good riding gear they obviously use for their big bikes. The cop in the paddy wagon didnt notice or know about real legit minibikes, because as soon as he saw them he put the siren on and went after them.
They would all be registered etc, these things are a rarity and im very surprised to see such a large group.
Awesome little things, it easy to see why they have cult status:
Edited by D.I.Y. Mik
Has anyone checked out Power Kart Raceway in Fyshwick yet? Pretty cool place and the karts are pretty quick.
Anyway they're planning on running a racing league fortnightly Wednesdays starting 15th of October.
Anyone who might be interested they have some details on a Facebook event - https://www.facebook.com/events/1467986283466197/
I'm planning on running it. Trying to get word out :)
Edited by dontyellpl0x
  • Like 1
I was blown away by the size of some things. Huge jars of Jam etc and Marshmallows that would Fill a Coffee Cup.
The Bulk buy factor is the main issue as the initial cost is a bit off putting but in the grand scheme it seems economical. (aside from the $60 yearly fee)
eg. Twin pack of Mocconna 400g jars of Coffee for $35 work out cheaper than when on special at Woolies individually but it's alot straight up.
Walking round snacking on Demo foods is cool though and a Hotdog and refillable drink for $1.99 is a Bargain. :D
Not likely to signup anytime soon though. (we went with friends who are already members)
The sweets section is pretty full on, and it is nice to have a 2 month supply of toilet paper, if you have the storage space.
There are some good things like the terry towels and microfibre cloth in the auto section. Good for detailing, theres always a clean rag handy.
But for me, not having to go shopping as often is the best part.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
