Heard someone here saying they commute Canberra to Sydney four times a week? Who was it again. Need to ship a bonnet from Wollogong to Canberra. Happy to give you a case or two of your favorite beer. Provided its not too out of your route.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
