Oh Anthony, you so lulzy :P
We miss your rants on how much you are having to spend etc.
Buy another one.
Or since you are a rich kent now...
buy this: http://www.sau.com.au/forums/topic/452229-fs-r32-gtr-track-project-nsw-aus-complied/
I honestly think that you should strongly consider submitting a more modern, topic-specific definition of insanity:
"Insanity: buying a second Japanese performance import against all financial logic"
Slightly on topic though, I'll definitely end up getting another modified import as a project some time down the line. The missus is likely going to go against all her emotions and let her MRT edition WRX go soon enough due to financial priorities, and we both agreed we'd totally get something to work on together when (yes, WHEN lol) we eventually move out somewhere together. (Un?)fortunately she really dislikes Skylines though lol, so who knows what we'd end up considering when the time comes....
Do a bike project.
Cheaper, easier, needs less space.
And because its a bike you can do quite radical mods legally.
I always wanted to do a Cobra, but they are so expensive.
Edited by D.I.Y. Mik
  • Like 1
Do a bike project.
+1
I would love a Cobra.
Track Project or street?
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
