Haha!!!  Been a looooooooooooong time old friend, how's things?
Buying that Pulsar way back then broke me good n proper.
Since selling my beloved R33 4 door, the R31 SkyWagon, the N13 SkyHatch and losing the B17 Pulsar to the ex, I have owned:
1 Subaru Liberty Wagon, 2 VS Utes, 1 VX Wagon,1 VY Wagon and I now own 1 Subaru Forester and 1 Mazda 323.
Nissans seem like a lifetime ago and I still miss Boost everyday.
Had some good times and fond memories here and now this place seems more than a little lacklustre.
Pity.
  • Like 1
We'll catch up real soon, if your in Canberra still. I'll send you my Mobile number via PM
Boondahs, Burbouns and Bitches are on the cards mate. Like to hear more about what's been going on.
I'm driving a Maloo R8 that is awesome, GTR's in the shop with John getting a 6speed Getrag put in and another rebuilt motor. Have a nice Nissan Pathfinder I'm doing up. Gave the Liberty to one of my sons.
  • Like 1
Hey Anf, yeah seems to have changed alot around here in my absence!!!
Couldn't do Coupes or Sedan again after having Hatchbacks, Utes and Wagons.
It'd have to be a StageA for practicality.
I've been scoping out a R34GT-4 for a few weeks.The guy is willing to sell it for 12k. It has problems with the front drive shafts. Anyway if I get the a car was going to swap it out the engine for a RB26/30 and gearbox to suit. Pretty much build a replica GTR all by myself to reduce on labour.
But the other side of me wants to save for a house deposit. Who knows maybe I could build this then sell it when time to buy a house comes. The fact that it's not a GTR means it probably won't hold value. Living without a line will definitely leave a hole in my heart. What would you guys do?
Sent from my SM-G935F using SAU Community mobile app
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
