Bought some splitfire coilpacks on tuesday and requested Express postage. I received notification that it was sent on Tuesday and was given the tracking number.. YAY!
But..
..I tracked the parcel on Wednesday, and it says that it was only picked up on Wednesday, and is currently in transit to the Canberra depot from Brisbane. No big deal, I'll receive it today (Thursday).
Today I tracked the parcel and it's still in transit, and nothing was on my doorstep today. So, it was sent a day later and I can only assume that it has been sent via normal parcel.
Ahh well, not like my car is motionless in the driveway..oh wait, yes it is.
Cliffs:
bought coilpacks and requested express post on tuesday
seller indicated it was sent tuesday, but it was actually sent Wednesday
coilpacks should be here by now, but they're not
Assuming it was sent by normal freight
Mad.
Here's the first demo model of the clapper switch I've been building.
Hopefully I'll be getting it into production soon. Price somewhere between $50-$100, bepending on how cheap i can get some gear in bulk.
http://youtu.be/oZ2jm-RbseU
I've always liked the idea of having a clapper light.
For ages I thought only rich & successful people in movies had them but now normal folk can have them as well.
You know you have succeeded at life when you have clapper lights!
Got heaps done on the car today.
Everything is off the front, just need to get the cam gear and vct off so I can do cam seals and put everything back together.
Just need to get a seal puller tomorrow morning to get the crank seal out, that sucker is in there tight. Bent my pick trying to get it out,
Hopefully I can get it all done before 7pm tomorrow otherwise i'll have to finish it after work on Wednesday.
Inspection failed (of course). Points:
Remove all non-compliant window tint (the rear quarter windows and rear windscreen are 5%, lol)
Rear muffler fouling body (stock muffler I borrowed doesn't sit correctly - hitting underside of car)
Boot grommet missing (there's a 5cm or so hole in my boot floor under where the spare wheel should be - gotta get a rubber grommet to cover it)
Display all child anchorage points (FUUUUUUUUUUUUUUUUUUU need to have these installed and then engineered. Le sigh)
I'll just peel the windows myself this weekend I suppose, then book it in at Canberra Motor Works to have the child restraints fitted and engineered in one hit. Grommet can be found at clark rubber lol....dunno what to do about the muffler fouling though, it really shouldn't be since there's nothing that can be 'adjusted' in the whole exhaust system...anyone got a rego catback I can trial fit/borrow to see if it fits any better?
Easiest way I found for tint removal is steam cleaner. Just be careful using it around ur demister. Can lend you mine if you're desperate?
I might take you up on that if you don't mind mate, the only other way I've had tint removed involved a razor blade, Orange Power, and lots of time
that is such a shame, guess I'll have to hold onto this dangerous seat for a bit longer. How come they didn't point out the tint and restraints first go?
hahaha yeah if you don't have a problem with that :P just don't ruin it lol
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
