  • Replies 196
I think you can in alot of ways. I think you read to many magazines imacul8.  :werd:
I think your heads to far up SST ass.
I looked at ecu's at length when buying one for my last car. Comparing the autonics, motec, apexi and wolf. So i actually do know something about them.
472bhp @ 18psi on SST Dyno Shootout Mode
11.13 @ 126.93 1.64 60ft on Full Slicks 16/10/04
11.67 @ 120.64 1.69 60ft on Radials10/04/04 DC
Got Boost,
Just looking at the times and power you have there.
I remember MattR's old RB25 powered R32 GTS-T running slicks. That ran a 11.3 @ 122mph with a TRUST TD06-19C Turbo, Microtech ECU, Custom Plenum. It made 318rwkw.
472bhp is approx 352rwkw. It appears around the mark.. :)
This is a link from the http://www.japanesemotorsport.com.au/movies.htm web page.
http://www.japanesemotorsport.com.au/white32gtst.mpg
Im not expert that is why im asking questions, can someone answer this?
The difference between the 2 dynos is hub vs rollers....
and one reads PS and the other reads HP
so tristan actually got 511ps = 504hp but that aint fk all so who gives a sh!t
what my real question is, because hub dyno cannot slip at the wheels, could it be slipping on the roller dyno back @ sst a bit to give it a lower reading??
can someone fill me in....to me a hub dyno would have to be more accurate if it was obviously a DD dyno...
This threads just turned to shit now. To many ****heads with nothing good to say. Just jealous ****s.
got nothing to do with jealousy simon and you know it.
ppl want to know facts, not be waved a wank showoff figure and then be told oh we dont want to tell you how it does it.
either share the knowledge or dont state it to begin with.
i know enough to get me by and this thread helps no one.
TJ u know there is no secret. It has a wolf pnp and a gt30 . you know this so dont make up silly things.
handed out any warnings yet ash :jk:
dont know if ash has, but i will.
guys, theres a tonne of info in this thread, its awesome, but just too much testosterone - chill out, discuss things nicely or i will close the thread and let ash warn as many of you as he wants.
Cheers,
Christian
Hi guys, I prefer to deal with facts that I can see, and I have a dyno graph that shows 438.7 rwhp, so I will work with that until I have some other facts.
Assuming the car has the standard gearbox and diff ratios and the usual tyre diameter, it makes max power at ~5,900 rpm. To me this seems a little low considering the cams have been upgraded. I would expect around 6,250 to 6,400 rpm for max power, so this in itself is an interesting result. The outcome of that is a shortening in the useable rpm range, which will adversely affects its times.
To run times commensurate with the max power, a car has to have at least 50% of the max power available after the upchange (1st to 2nd being the widest ratio change in a Skyline gearbox). The dyno graph shows 420 rwhp at 6,500 rpm and 160 rwhp at 3,500 rpm, this is less than 40% (38% in fact). So in my ever so humble opinion, the car will never run the times in line with its max power until the resulting "hole" in the acceleration curve is fixed or a close ratio gearbox is fitted.
The rather savage drop off to ~100rwhp at 3,000 rpm will make getting it off the line extremely difficult, I suspect it will either be bog and die or wheelspin city. It will need someone of reasonable experience and quite a few runs to get anything like its best. Even then it will still be a compromise.
The average power (3,500 rpm to 6,500 rpm) works out at 345 rwhp, which is very respectable and only around 20-25rwhp less than I would have expected.
Bottom line, based on the max power (438.7 rwhp) it should do 11.6/7 at ~125 mph, but my guess (and it is a guess) would be lucky to get into the 11's at all.
My 20 cents worth.:rofl:
PS; it always makes the power curve look nice when you start it at 80kph (~2,900 rpm) and stop it at 180 kph (~6,450 rpm).
SST is a workshop and as such will not tell any of our secrets but wiil make the cars avalable to any East coast shop thats in town.Magic1 is driving his car around for work as was on sat.
If others cant match this power then try harder.
Magic1 wanted as close to 500 as pos for PAS so we should be pleased he got what he wanted.
R32-GTS... This is the post the caused the problem.
If its as simple as running huge fuel pressures then say so.
Instead of just stating.. 'stock injectors' state stock injectors running x amount of base fuel pressure with a rising rate reg. that runs at 1:1 or something.
East V West net wars.How sweet.
Please Ash stop this thread and after your WA visit you can be the East coasts judge of fact.
enough is enough.
I'll be coming to WA, with (or without my car it seems) and ill see what the story is first hand.
thread closed - ash
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
