  • Replies 85
whos the dude on here who just got a GTRS tuned on a 33? he got i think just over 250rwkw on 1bar, so i think there should definitly be more in it with more boost, which would put it quite ahead of the 2530- which is a good solid street turbo, which can only be faulted for running out of a bit of puff at the very top end.
For the price of the GTRS's at the moment they are a steal.
There seems to be lots of support for the 30xx series, looking at dyno runs the power looks like a light switch (i even think the 2835 looks to come on pretty hard) are these really good for the street? surely 3rd gear would bag street tyres just coming onto boost, let alone trying to accelerate hard in 1st or 2nd? Sounds like fun, but frustrating when lesser powered cars beat you to 100!
I have a 2835proS on the way at the moment. Going to have to run R-compounds full time, as the 2530 already fries tyres with its paltry 220rwkw! :)
building a RB25DET with a TD06-25G, nice laggy turbo with good topend power, and a misfiring system to keep the turbo spooling while I'm off the throttle. The one that I've bought is a metal sleeve thingamajiggy (can't remember the name) so its not steel bearing or ceramic, and can withstand a lil bit more punishment than a standard turbo.
As a standard swap/upgrade for a R33 RB25DET i'd say get a 2530, but I dunno how they react to RB25DET Neo's.
Funky you have been talking about this setup for about 1 year now, when the hell will you get all these antilag thingamergiggies done?
SLY33
Is the 2835pro s going to fit on the stock manifold without modifications?
As for traction, good tyres and decent suspension setup helps alot!!!
SLY33
i hope so! i think it all bolts up. Kit comes with its own dump and all the lines. I think the one thing ill need is a new intake pipe as the compressor inlet mouth looks big, but im fairly sure its a blot on kit.
can someone with ~280rwkw comment on drivability? are these cars still fast at speeds below 100 or is it just wheelspin city?
While i love power, it makes you slower if you cant get it down!
Damn impressive resutls...are you sure it was only 13psi:confused: I have read of those sorts of power figures at 1.3bar. Is it a std RB25:
No its not standard. I dont know what has been done other than bigger cams, injectors, external wastegate, it was a import this is how it came. It was dynoed by Brad Sherriff in Tassie.
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
