Yeah I thought it was a community thing too but obviously not.
Nah it's a lemon... let's see whats gone wrong so far...
air inlet pipe not screwed in
steering rack boots broken
cat not screwed in tight (exhaust doesn't fit right, it scratches/hits a bit of the underside of the car)
clutch slave master secured with one bolt half screwed in (yes really it was hangin off the side of the gearbox)
engine not secured (yes really it wasn't screwed in AT ALL)
rb20 loom still all over the place (it caused a fire)
intercooler welds have drips on the inside of the pipe of welding
turbo oil return line not long enough and made out of bent improvised hot water pipe or some shit (it fell off when i was driving, almost caused a fire, and when the mechanic looked at it he said i should buy a lottery ticket cos he was suprised my turbo did not blow up with that pipe on it - it was hose, pipe, hose all in one)
gearbox leaking (and syncros ****ed)
engine leaking from multiple places somewhere (tba)
3/6 sump screws had broken heads (ie they just screwed the sump on, broke the heads, knew the screws were useless and not holding it in and just left it)
rear brake pads were pure steel (burned holes into the rear rotors so large chunks of metal were actually missing)
front pads non existant ("DO NOT change your pads they will last you for a long long time" the point was actually made when i didnt even ask..)
RHS wheel bearing done up so tight it ****ed the hub (had to buy a new one, this wasn't old, the people who put it on just did it up waaay too tight..)
LHS wheel well not watertight (after they shoved the loom in, this still leaks in the wet)
multiple T connectors with a screw shoved into it as a "poor mans straight connector"
injectors = ****ed (caused pinging, they've been resprayed a different colour too for some reason)
intercooler piping joins frayed and getting rubbed through on the body
air con condensor left in car with fan still on/attached when there is no functioning air con (ie they removed half of it and left pipes in the engine bay)
exhaust leaking in multiple spots (they didnt use gaskets)
multiple wires I've had to replace that have been about 1/10th of the current load requirements of that circuit
not to mention the numerous other dangling tubes/cables/wires
That's just what's happened to the car since I've owned it so really I'm the ****wit that bought it so it sucks to be me haha I'm dissapointed really more than anything but it just goes to show some people would sell their own grandmother if they could.
As for the previous owner he reads these forums so far he hasn't said much since things started to go wrong. Most of the guys helping me have been especially ceffo and too_much and everyone else who has suggested things and given me advice/info.
I mean I have to look at the positives ... I can say I was in a car going about 260kmh without the engine being bolted in.. can you say that?
  • Replies 199
Jesus...thats a sorry list of probs:( I take it you didnt get the car inspected? If not i perhaps understand why:( Shame im not in the same position i was in 12 months ago, unemplyed, bored in Sydney with tripple garage:(
Again all the best getting it sorted...half the battle is sussing out the probs, and it sounds as though you have your head around the probs...again good luck with it all:cheers:
Thanks mate - I hope you're now employed, not so bored but still got yer triple garage :)
So far yeah with some help from peoples here and there and generally having problems fall out (in some cases quite literally) I think there are most of them. Off course I'm not listing the ones that aren't really problems at the moment like the exhaust knocking on the car when you're travelling and minor stuff like that but with any luck we'll have a nice clean reliable car in the near future!
Well its pretty obvious that there is not a lot of bad luck in that list.
Damn, i had no idea it would be that bad.
Mate, if i had enough knowledge i would love to help out.
Its time, i got off my ass and got my cefiro registered (hopefully i wont have quite the same troubles as you) and then i can join in the cefiro team drift. :)
I'll take your turbo, and your rear bar..
oh wait, I already stole your rear bar, and i'll just drive behind you one day and pick up your turbo after it falls off :P
OUCH....that was rough.......lol......I suppose you are allowed to say that considering you have been helping with the issues ;)
Actually i wouldnt mind a new gearknob.
Whats your address again?
Let's all share I say heh heh :hippy:
Actually hopefully I'll get this thing stitched today and show ya how it turned out - if it goes good then everyone else will know how to fit Jays r32 gearstick+handbrake boots fit a cefiro :P
oh wait, I already stole your rear bar, and i'll just drive behind you one day and pick up your turbo after it falls off ;)
heh :bahaha:
My car has probs hahaha.
I have the dreaded 4000rpm miss from the coil packs, mega play in the steering, exposed wires in the wheel well, gearbox mount is gone etc etc... its all good though. Im happy its finally registered!
Well hello there CC, seems we have a one-sided post here, lets enlighten the rest of the group shall we?
No I can't recall this myself, but when was the last time I didnt answer your call? Or any of your calls for that matter?
Now for the car condition, the car was driven for 6 months prior to your ownership and yes, 2 times, there was an electrical issue which I was assured was fixed. Perhaps a word to the autoelectrician is in order. Most of the issues you are talking about really are minor and to be expected in any older vechile, except for the turbo oil line which was fitted by ice performance when I supplied braided lines.
With regard to the aircon, I had already mentioned to you it would not be worth retro fitting. Not happy with the gearbox? Well I did throw in a Bride seat that was not part of the original deal and is worth a pretty penny.
You make no mention of the $200 I gave you for the supposed stuffed steering rack which wasn't stuffed at all but only needed a new boot (for the princely sum of $15).
Do you even recall what I told you to do when you got back home from picking up the car? Here's a reminder, get it put up on a hoist so you can check it out. Check the brakes, suspenion, undercarriage as I hadn't had a chance to do it and most cars that are 15 years old do have some issues. Is this the first thing you did? The answer to that is quite obviously No.
I sold the car in good faith at cheaper than the market value because it was in "as is" condition. Had I done the work required the price would have been easily $5-7k higher, more in the realm of where Riverside and Ni are selling their cars. You were aware of this and accepted as this gave you a chance to do the things you wanted to do and have a car to drive.
You have bought a car with proven performance, lots of name brand parts, an 8 page feature car in a current magazine and drop dead traffic stopping looks for an absolute steal.
Judging by your comments and expectations, you would have been better off buying a new or nearly new car. Reading some of your posts where you said you might have been better importing you obviously havent seen some of the issues and costs people have with importing highly modded Cefiros.
Meggala.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
