heres the dyno sheet for my other entry
stock turbo
series 2 gtst
040 fuel pump
malpassi 2:1 regulator
HKS Mechanical Boost gauge
HKS pod
HKS type-s intercooler kit
HKS Old school sequential BOV
HKS 3.5 inch Cat back exhaust
SS Auto chrome Split dump and 3 inch front pipe
Turbosmart bleed valve
Apexi power FC ECU and Commander
Apexi turbo timer
And this run was done on 275/30/R19 tires
1995 R33 GTS-t
HKS GT2530kai turbo
3" Turbo Back Exhaust (Split dump pipe)
Custom Exhaust Manifold (TuneAgent)
Hybrid FMIC
Blitz POD
Apexi SAFC II
SARD Fuel Regulator
BP ULTIMATE 98ron
Dyno @ 1.1bar = 232rwkw
Coming Soon...
Fuel Pump
Injectors
PFC
Edited by MKDR33
I have a r33 94 series 1 with
Full exaust 3' into twin pipes 2' each
ITS Turbo T3 T04E
35mm tail gate
044 fuel pump
Nismo Fuel Pressure Reg
standard injectors
standard AFM
Apexi air filter
Apexi Powerfc
Apexi Pfc boost kit
Universal FMIC
Hks ssqv
Exedy heavy duty clutch
Machined and balanced crank
87.0mm Arias forged pistons
standard head
262rwkw on 18psi
Edited by str8g
ECR33
stock turbo
stock boost 7.5psi = 0.5 bar
HKS pod filter + custom CAI
Apexi PFC + Datalogit
FMIC
split dump
3 inch front pipe into 3 inch cat
3.25 inch Blitz cat-back system with 2.5 inch bolt-in baffle restrictor in place
98 octane Caltex fuel
Splitfire coils
result 223hp = 165kW
sorry for the size of attachment don't know how to resize yet.post-19642-1150288704.jpg
  • 3 weeks later...
465rwhp/347rwkw at 21psi on pump gas (93 octane in the US)
Stock head, stock cams, stock intake manifold.
Wiseco Pistons, Eagle rods, custom headgasket w/ARP's
550cc injectors, Nismo AFPR, Walbro 255.
GT35R w/Tial 38mm WG
Custom side dump exhaust and wastegate dump
AEM EMS
The car can make MUCH more power easily. The coilpacks weren't liking the higher boost, so it's time for Splitfire's I guess.
Edited by SleepingTalon
I had a Sliding Performance Highflow and made 220rwkw on 12 psi
I ended up running 17 psi shortly after but dont know what sort of power i were making on 17 as i didnt have it dyno'd
Mines ECU
3" turbo back exhaust
FMIC
Dual Stage boost controller
Pod filter
And the Sliding Performance Highflow turbo
Sliding Performance has just finished my complete engine rebuild and ive upgraded to one of his Biagio GT3076 turbo's.
Just finished running it in and it will be dynoed on Tuesday :D
Evo 8
motec
exhaust
unknown tune state + boost
R33 GTST
powerfc
fmic
exhaust
12psi
clutch etc
both on the same dyno, just a comparison.
the evo has more average power everywhere
made 251rwhp on 10psi hiflow standard turbo 450hp
front mount
z32 airflowmeter
3inch dump pipe
pump fuel
http://www.tuffstreetcars.com/skyline2.pdf
http://www.tuffstreetcars.com/skyline.pdf
ran into probs with nock and boost
max 13deg timing and lot of knock could not run anymore timing or boost into it.
Edited by Turbo Dan
With so many threads about turbo upgrades for RB25's i thought itd be a good idea to start a thread that shows results only, as the results from various threads are scattered everywhere. Everyone has there own ideas about what power they want so obviously there isnt ONE perfect turbo upgrade for everyone.
Please post your RB25 dyno graphs only and state the following:
-Engine management
-Boost ran
-Fuel used (pump or special)
-significant engine mods (eg cams)
The idea of this thread is to be a quick reference to various turbo's performances on RB25's, not to be a discussion thread.
Thanks
(If this has been done already let me know, but didnt come up one in search.)
just got my rb25 powered r 31 back from tune
rb25
microtech
gcg hi flow
fmic
standard injectors
3 inch turbo back
98 ultimate
walbro pump
216 rwkw on 10 psi
240 rwkw on 16 psi
GTST sedan 94 model
powerfc
555cc injectors
040 intank pump
hiflow turbo to4e wheels
apexi air intake
straight through zorst
no cat
98ron fuel
1.2bar
micks front mount cooler
standard internals
347hp @ wheels
im happy with this result
Edited by R334door
r33 95 S1.5 GTS25T
230 Rwkw @ 12 Psi
T3/T4 Highflowed VL Turbo
GTR FMIC
GTR Fuel Pump
Apexi S-AFCII (12:1 AFR)
3" Exhaust Turbo Back (inc. Highflow Cat)
K & N Pod Filter
Irodium Spark Plugs
BP Ultimate 98 Octane Fuel
Stock RB25DET engine.
AFR
Boost
I've noticed the S1.5 r33’s in this thread seem to be making more efficient power (over the S1)? Maybe just a coincidence.
Edited by geno8r
R33 sII
Gt spec front mount
3inch xforce turbo back "race exhaust"?
5-9PSI (low3000rpms-high5000rpms)
and know idea wat internals
KSP tuned stock ecu
218kw@ 6000
Dyno may be wrong???????
or some sick internals????
s2 r33 gtst
rb26 crankshaft
Tomie forged Piston/ring set
Nismo bearing main/conrod set
GTR N1 oil pump
GTR fuel pump
3" Trust dump/engine pipe
3" Apexi exhaust
Apexi power fc
hybrid intercooler
12 psi
standard turbo
193.0 rwkw
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
