R33 - 1998 Series II GTSt
Stock Turbo - boost 12psi (bleeder)
FMIC
APEXi Pod
Power FC (Hitman tuned)
3" turbo back zorst
194.6 rwkws (feels awesome !)
Recently
Upgraded to HKS 2535 but only on R32 actuator 10psi.
Needs a retune but feels nice.
Can't wait to hit around 250rwkws.
Have GTR fuel pump, S15 injectors and Z32 waiting to go in. Yeehar !
Doing everything myself which can be slow going but very rewarding.
iLEC : Looking forward to your results dude :)
1999 R34 GTT 2 Door Coupe
Stock Turbo
Power FC
12 PSI boost with AVCR
FMIC
3inch Turbo Back exhaust + Screamer Pipe
Apexi Pod Filter
= 218.7RWKW
Edited by anDru
R33 gts-t
apexi power fc
blitz frount mount cooler
nismo fuel pump
z32 AFM
AVC-R
Split dump pipe
Custom Garrett highflow turbo
Thermo fans
Stock internals
Stock injectors
256 rwkw at 1 bar
Will post new dyno sheet when I scan it in.
Thanks to Paul Fisher at Pulse Racing (Menai - Sydney) - Definately knows his stuff, i would not go anywhere else.
R33 gtst s1
wiseco pistons 20thou
acl race bearings
Trust 1.4mm head gasket
gates timing belt
walbro fuel pump
700cc inj
power fc
avcr
GT3040 .63
s/s manifold
tial 38mm external wastegate
bov
k/n pod
4" intake pipe
Q45 afm
custom fmic
full 3" exhaust
Just tuning no power runs as such we made 240rwkw on just under 14psi, due to missifre problems we couldnt wind the boost up anymore and get some good power runs DOH
Next mods....tomei poncams
splitfire coils and more boost
Edited by sinistagtst
ECR33 Type M
Blitz LM FMIC
Turbo-back 3" exhaust
Splitfire DIS coils
APEX'i Power Intake Pod filter
UAS cold air box
GReddy Profec B-Spec II
GReddy e-Manage Ultimate
Tomei exhaust cam gear
Walbro fuel pump
0.85bar
205kW
http://members.optusnet.com.au/govich/after.jpg
Edited by govich
rb25 s2
wolf v4
fmic
040
blitz sbc id3
3" straight through with highflow cat - no mufflers
old turbo off my rb20(highflow n shiz)
555inj
gates timing belt
ss intake pipe(fluuttEr yo)
stock internals
sticky wastgate
200kw
to come;
custom cai and a fixed wastegate!
hks 3037 pro s turbo with custom housings..
big shout out to vic at EAS Performance!
S13 Rb25 DET
Stock internals
Stock turbo
Apexi Power Intake
FMIC in and out on the same side
Microtec LT12S
Splitfire coils
BATMBL dump and 3 inch Exhaust
12 psi boost HKS EVC IV
Bp Ultimate
Bosch 044
Malpassi
=209rwkw
96 series 2 r33
3 inch turbo back
fmic
stock turbo I think (has steel front wheel maybe series 1 turbo???)
profec b boost controller 12psi
high flow fuel pump
174.8 rwkw on 9 psi and 200.2rwkw on 12psi
havin trouble uploading at the moment.....
1996 Series 2 R33
Mods I have (In order of installation):
Car came with:
3.25 inch cat-back. (1998 5Zigen Border series)
K&N Pod filter.
Blitz SS B.O.V.
Mods I have installed so far:
Custom 3 inch dump pipe
Metal-cat (Magnaflow 650 CFM cat)
Garrett GT3076R w/IW turbo
Turbosmart Boost T
Hyperperformance Automotive FMIC (ebay choina)
Cold Air Induction (To underneath of pod from front bar.)
Exedy heavy duty organic clutch kit.
Will start at 8psi then go to 10psi then 14.7psi once more. Was running 1bar (14.7psi) before my clutch eventually wore out from slipping, I suspect I have a Fuel Cut Defender that I am not aware of.
Dyno this Friday if all goes well.
Edited by Pauly33GTS-t
R33 Gtst S1
Results as per my signature... currently 226.5RWKW (will scan dyno sheets in tonight)
More goodies being installed currently with ECU to be installed next week:
555 Injectors
External fuel pump
FPR
ECU (Adaptronic)
Custom Plenum
Metal Headgasket
Cam Gear
Cam Shafts
New hoses throughout engine just incase lol...
GT3540 for when Stage 3 highflow is max'd out
And then..... wait for stock internals to crap themselves before installing a RB30 bottem end :) (Dad won't help me build the bottom end whilst there is a perfectly good one still working in the car :P)
S1 1994 Gtst
Stock auto ecu (had manual conversion)
Stock turbo @ 11 psi on GBF bleed valve
Stock internals
Gates timing belt
Fmic
SAFC2
Split dump, hi flow cat, 3" cat back(front pipe still to do)
Xtreme 9 puck clutch
K&N panel filter
550hp warlbro fuel pump
271rwhp or 200rwkw
R33 Gtst AUTO..Dyno'd at hitmans
-s2 running gear
-exhaust, split dump wrapped/two mufflers old cat, quiet restrictive.
-FMIC (copy hybrid)
-Hi-flow turbo (hi-flow front, vg30BB rear)
-rb20det acuator, running 10-12psi.
-SAFCII
-Pod Filter (not enclosed)
-Stock everything else
-BOOST98 fuel from United servo's.
234.9rwkw@10-12psi (315rwhp)
Please Note: Done in 3rd gear, car slowly ramped up in 3rd so it would not kick back into 2nd.
R33 S2 97
Mods:
FMIC
Splitfire coils
Walbro fuel pump
PFC
3inch dump to back (just found out that the cat is still 2.5inch!)
Stock turbo
Stock internals
Tuned by JEM, had over 200rwkw at 14psi but knocked it back to 13psi for a safe tune,
196.4rwkw.
Next mods to be made,
GT3037 turbo
Tomei poncams
550cc injectors
Anyone care to guess how much i'll be making then?
Okay just had a re-tune and it made 198rwkw at 12psi.
Edited by AdamsR33
In response to the call for a stock turbo dyno sheet, mild mods. See link below.
94' ECR33 gts25t Type M
KLS 600x300x76 FMIC
HKS Exhaust from dump, 3" to 3.5" superdragger High flow cat (was on car from japan, other than that it was stock)
K&N Pod.
AVC-R EBC.
it made 194rwkw @ 6200rpm. = 260.3 rwhp @ 13psi .
*after looking at the Dynosheet I noticed my AFR's drop quite low. Need a good tune as its runnin a little bit rich.
http://members.optushome.com.au/nastradama...dale260rwhp.jpg
this is my benchmark, will be udpating with all new mods when santa arrives :blink:
Edited by silverbulletR33
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
