1996 R33 4 Door GTS25T 4 Speed Automatic Sedan
Standard:Turbo/Fuel Pump/Dump Pipe/Injectors/
Impul ECU
Full 3" Exhaust/Front Pipe
FMIC
Splitfires Coil Pack's
SAFC2
stage 2 shift kit(Mike At MV Automatics)
TurboSmart bleeder Valve/boost controller.
Massive K&N Pod Filter With CAI
9/10 psi
198.9 rwkw
Hey Guys
1993 R33 GTST s1
standard ecu
Stock injectors
Stock internals
Stock Turbo
Walbro 500hp pump
Splitfire Coilpacks
Greddy profect b 2
Bp Ultimate
X Force 3 inch turbo back, 3 1/2 inch cat back
183.5 rwkw running 11 pound. :)
Had my car retuned.
Here are the numbers and a list of mods.
RB25det spec 2
GT3582R .82ar
Jun style intake
90mm throttle body
550cc Delphi top feed low impedance injectors
JGY fuel rail
Aeromotive FPR
Walbro 255hp fuel pump
Tial 44mm v band waste gate
Hallman boost controller
3" ss turbo back exhaust
Top mount exhaust manifold
Apexi Safc 2
Apexi ITC
93 pump gas
Spec stage 3 clutch
Synchronic BOV
FMIC
Z32 MAF blow threw
This is a 2698lb with driver in it 240sx.
This is at about 17.5 psi. This is rwhp.
Edited by JonTurpening
R33 GTSt
HKS 2835 Pro S kit
Power FC
Nismo 555cc injectors
Tomei fuel pump
Z32 AFM
Hybrid GT spec FMIC
Apexi Pod
Tomei 256º Poncams
Blitz EBC
244rwkw @ 13psi
Clutch was slipping when the boost was over 13psi
hoping for 270-280 once fully tuned
ps. This turbo sounds f*cking beautiful when spooling, love it
1998 R34 Skyline GTT tiptronic auto
Mods:
3" TBE exhaust
FMIC
Splitfire coils
generic pod
turbotech boost controller set at 11psi
Walbro 255L fuel pump
Apexi SAFC NEO
Fuel - Vortex 98
Made 199.3rwkw
Edited by colossus
This was a quick touch up tune for Texi after running in the engine.... proper tune with more boost in 2 weeks - stay tuned!!
R33 S1 Skyline
Garrett GT35R - 0.63 rear externally gated (0.82 on standby, just want to max this rear out first )
6boost manifold
38mm turbosmart ultragate (needs to be upgraded if keeping the smaller rear housing on)
3" exhaust with metalcat - proper mufflers, no cannons....lol
Greddy E-01 boost controller
550cc injectors (740cc nismo's on standby)
Haltech E11V2 - wideband 02 and display also installed
greddy intake
rebuilt engine - forged internals 20thou oversize - 4,000 odd kms old - Rebuilt by Dave aka T04GTR *shameless plug :(
Some little tricks done to the head - wouldn't tell me :O
Step 1 poncams
FMIC
Walbro 255 (044 being installed prior to final tune)
Sard FPR
*cough* retuned, well finally tuned not just a quick touchup to get through some events after the rebuild :P
Soooo it took two months not two weeks to see what I could max the 0.63 rear out at.... nothing has changed except the 044 was installed and the FPR actually turned up a bit...
345.2 rwkw @21-22 psi..... kw sheet has AFR's and the HP sheet has the psi :)
hmmmz now bigger rear housing time :D
  • Like 1
mods:
HKS 2835 pro s
PFC
greddy exhaust cam gear
nismo 555 cc injectors
nismo fuel pump
Z32 afm
Blitz DSBS spec S
3" zorst
De-cat pipe
other usual supporting crapolla, (fmic, clutch, etc etc etc)
R34 GTT manual
PFC
Custom FMIC 600 x 300 x 76
Greddy/Trust - T67/TD-06SH25G Turbo Kit (This kit is now for sale, see my sig)
*T67, Compression Housing 25G, Exhaust Housing 10.0cm2
*Trust RB20/25 High Mount Exhaust Manifold
*Tial - 44mm External Wastegate 10psi Spring
Nismo FPR
Nismo 600cc
Tomei fuel pump
3" turbo back
R33GTST 4 door with:
GT3071 .82 housing.
Bellmouth dump with internal wastegate to 3" exhaust.
Power FC
Hybrid cooler.
550 Nismo injectors.
Stock air box.
Stock engine.
p><p>                               <a  href=http://www.skylinesaustralia.com/forums/uploads/1215946577/gallery_23164_2695_174640.jpg' alt='gallery_23164_2695_174640.jpg'>
rb25
hks2535 - 18psi - running boost off actuator
Standard Internals
Standard AFM
Standard Injectors
GTR fuel pump
apexi n1 cat back exhaust (i know i know, i should really change my dump/front/cat)
arc airbox
237kWs @ 18psi
Edited by DjeMz
R33 GTS25t, automatic
Walbro pump
Garrett T04
600x300 FMIC
Split dump pipe, full 3"inch exhaust
Boost tap running 11.5 psi
SAFC II
192rwkw, with exhaust manifold leak and silencer on the muffler.
Getting a new manifold gasket. And going full ECU, LinkPlus or EMS Stinger.
Will post up results in a weeks time when its all done.
Mods:
HKS 2835 pro s
Tomei 256 poncams
PFC
sard 800cc injectors
Bosch 044 fuel pump
Z32 afm
Greddy Profec B Spec II
3" HKS Silent HiPower Exhaust (with untouched x-force high flow cat)
HPi FMIC/Exedy Clutch/CAI/HKS Pod
272.9rwkW@~18psi
244.1rwkW@~14psi
RB25DET:
CP pistons 9.0:1
SPOOL rods
256 Poncams
740cc Nismo injectors
Nismo pump
Cometic 1.2mm gasket
ARP Head,main,rod bolts
Highmount manifold
4inch HPI filter
Greddy Plenum
GT3076.82 turbo
Custom dump/front pipe
4inch Metal cat
3.5inch Fujitsubo exhaust
Turbosmart Ultra gate(too small) Going to Synchronic 50mm.
Haltech E11V2 w/3bar map sensor.
Run in tune on 17psi: 292.5RWKW (Will upload dyno sheet soon)
Power run will be at 22psi stay tuned!
Nismo thermostate
Nismo high flow fuel pump
sard 850cc injectors
Nismo flywheel
Excedy custom clutch
Eagle conrods
ARP head studs
Arias pistons & rings
Acl engine bearings
Sard fuel regulator
Nissan N1 oil pump
Apex power FC
Greddy boost controller
Greddy blow off valve
Greddy intake plenum
Catco stainless high flow cat converter
hks 3-3.75 inch exhaust
hpi split dump pipe
Splitfire coil packs
Front mount intercooler
Arc air box & cold air duct
HKS valve springs
HKS cam shafts 256-intake
HKS cam shafts 264-exhaust
HKS turbo kit 3037 pro s kit
Bosch Z32 air flow meter
40mm radiator
made 303.6kw atw on hi boost
291 kw atw on low boost
Edited by WARLORD
r33 s2 rb25
sard 550cc injectors
os giken exh cam gear
custom s/s high mount manifold
turbosmart 44mm progate
garrett GT30307R turbo
microtech lt12s
plazmaman plenum
280rwhp @ 8psi
335rwhp @ 13psi
preliminary tune - just getting it running and back on road again, retuned with new TPS and 17-18psi soon. :D
R33 gts-t 1994
garret gt 3037 topmount
hks intercooler type R
nismo fuel pump
nismo fuelpressureregulator
splittfire coiler
hks 555
greddy plenum intake
wolf 3d w400 squirt
hks airfilter
turbosmart 38mm exstern wastegate
3"exhaust from turbo
410.9 HP at backwheels at 1.4bar.
Rebuilt engine using new OEM rings, new bearings and other internals. I ported the head and exhaust manifold.
The head had a valve job with new bronze guides and was shaved.
The block was decked. The crank, harmonic balancer and flywheel were balanced. All machine work performed by Nagoya Precision. I assembled the engine with advice from Fujii Dynamics.
ECU and boost control settings by Fujii Dynamics.
Fujii says the ignition system is tired, high boost misfire at 17 PSI.
About 315 horses at the wheels.
Power FC
HKS pod filter
HKS Super suction
Q45 MAF GT-R
FMIC
HKS 2530Kai turbo kit
HKS SSQV
HKS EVC V
HKS 1.6mm head gasket J
JR split/dump pipe
Resonator/Cat back exhaust
Nismo Timing belt
HKS exhaust cam gear
Tomei Poncams Nismo
555cc injectors and fuel regulator
GT-R fuel pump
RB25DET:
CP pistons 9.0:1
SPOOL rods
256 Poncams
Nismo pump
Highmount manifold
4inch HPI filter
Greddy Plenum
GT3076.82 turbo
4inch Metal cat
heya all, just thought id include mine:
1995 R33 GTST
- Stock turbo
- Greddy cooler
- Walbro pump
- Full exhaust, dump and cat
- Turbosmart boost controller 10psi
- SAFC2
183.4rwkw .. prob around the 190-200rwkw mark , if we'd let the car cool down for a final run. The dyno result was after 2 hours of tuning.
http://www.skylinesaustralia.com/forums/Wo...fc-t232836.html
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
