Mainline Dyno 450 Kw on 98 Octane
This ER34GTT is running a RB25 with a nitto stroker 2.8 kit.
A Haltech Elite 2500
Just a quick comparison running V Cam Off and On
Boost duty was left the same.
Pump gas
450kw on 25psi with VCAM
and
400kw on 24psi without.
50KW gain!
Tuned by Jacky @ #sthitec #jtune_nz
Yelsha D Trigger Kit, YelshaD Billet Cam Covers, YelshaD Water Pump Blank off, YelshaD Alternator Kit, YelshaD Fuel Bulk Head
Edited by DCJ Panther
  • Like 2
On 14/08/2021 at 12:46 PM, iruvyouskyrine said:
Do you mean VCT or V-Cam? I don't belive you can have V-Cam with billet cam covers
It’s VCT/RB25. It’s not a Subaru sprocket that vcam uses.
  • 1 month later...
Engine: RB25DET Neo with stock internals
Haltech Plug n Play ECU
HKS Airfilter, HKS Silent Hi-Power Exhaust Catback, GT28 Turbo, R8 Ignition Coils, Fuel Pump, Intercooler.
Rest is stock, including stock Catalysator and Intake (Street legal in switzerland)
Aprox. 320kw
  • Like 1
  • 1 month later...
R34 GTT
Rb25det NEO Stock Cams, factory engine
HyperGear ATR45SS-RB26 Turbocharger
ID 1500cc injectors
Twin Walbro 525L fuel pump
Adaptronic Plugin ECU
600x300x81mm PWR Cooler kit
3inches turbo back exhaust
4inches intake pipe with Pod
Split fire coil packs
T3 high mount with 50mm external gate
Car made 390rwkws @ 26psi, E85 fuel. 22psi @ 3500RPM.
  • 3 weeks later...
Hi, My car nissan 200sx s14
rb25det neo full stock engine
GTX3076 Gen1 Turbo
E5 Fuel Pump
Ecumaster classis ecu
985 cc bosch
oem ignition
1 Bar Boost
Mustang Dyno 330 WHP (this dyno is always low power 😎 )
100-200 km/h 1 bar 9.8 second
100-200 km/h 1.4 bar 7.53 second
car weight 1350 kilos
60.thumb.jpeg.2039761e3898398dc92d84c892a27614.jpeg64.thumb.jpeg.510396f9e9d2d24ef3c238f42d2fb4c2.jpegIMG_3155.thumb.PNG.bb4b73936863459addb239226a529d0e.PNG
Edited by webomur
  • 3 months later...
R33 gtst
Rb25det nitto I beam rods cp pistons, head studs main studs, completely stock head including cams
2x044 pumps   Garret gtx3076gen2 3" exhaust no cat power FC and z32 AFM tuned on e85
Main line hub dyno                  414kw @24psi                        348kw @20psi
Edited by Hpjunky
Miss spelling
  • Like 4
  • 2 months later...
Nissan R33 GTST Drift car
Forge bult Rb25det Neo engine
Stock head with upgraded valve springs
Nitto Pistons and Con-rods
HyperGear ATR43-SS3 Pro Externally gated turbocharger
6 boost manifold and twin Turbo smart 50mm gates
ID 1650cc injectors + Walbro 520 Fuel pump
Forward facing plenum
Front mount PWR intercooler kit
Fuel system maxed at 465rwkws @ 23psi, full boost by 4K, E85 fuel.
  • Like 2
  • 1 month later...
HyperGear ATR43-SS3ProR Externally gated turbocharger
Twicked this turbo alittle bit, Made same power, picked up another 500RPM of response and 100kws in mid range at same boost level or 23psi, still running out fuel even with an extra pump.  I think the original version of SS3Pro would peek 70kws more at full capacity.
  • Like 1
  • 5 weeks later...
R33 GTST
Rb25det NEO Stock Cams, built buttom end
HyperGear ATR45SS Turbocharger
ID 1500cc injectors
Link ECU
3.5 inches turbo back exhaust
Car made a super responsive 512rwkws plumbed back @ 32psi,  and 500rwkws externally gated @ 28psi, full boost @ 4000RPM
Edited by hypergear
  • Like 5
On 16/06/2020 at 10:39 AM, Dose Pipe Sutututu said:
Time for an update to the shit box, this time with bigger and badder dose pipe for you dose bitches. Nearly 3 years in the making too :D
407kW @ 2bar -> 1.8bar  on E85. Mainline AWD dyno, with 16kph/sec ramp rate.
Mods:
  • Garrett GTX3576R Gen 2
  • Garrett T3 1.01 divided rear housing
  • Turbosmart Gen V 50mm
  • Sinco T3 twinscroll, single gate manifold (pulses split to the gate seat)
  • 3.5" Turbo back with 5" body Venom Cat, 2x Mufflers
  • Generic built RB25DET NEO motor
  • Spool billet oil pump gears
  • Tomei 260/9.15 Poncams
  • 80lb Valve Springs & Ti Retainers by Performance Springs
  • HDi Hybrid 76mm eBay FMIC (holding back the power)
With high IATs air density is dropping, thus boost is bleeding off as well with small DC corrections on the boost DC table. I did order a Plazmaman Pro cooler but it didn't arrive on time. IAT peaked at 57 degrees C in a dyno room with an ambient temp of 19 degrees C. From the data, reducing the IAT will improve the boost control up top, get more air into the motor and will yield the results I'm after.
Once the FMIC comes, I'll be back for round 2.
Special Thanks to:
  • Alex at Birrong Automotive for allowing me to use his dyno
  • Adam at Weldspeed for the fabrication work
  • Yez Racing for supplying most of the parts
Data, etc. available in my build thread here:
Sorry for the lack of derived RPM, I forgot to set it up, in the Analyse screen it shows you true RPM vs. Power vs. Torque.
Log during run:
IAT post run:
Time for an update, same turbo but refreshed motor now with 437.9kW at 1.7bar boost dropping down to 1.5bar towards the redline. Looks like I've maxed out the compressor at this stage. I believe there are some improvements to be had such as venting the gate to atmosphere and deleting the cat.
Will be back to get the closed loop boost control dialled in when I have time. Was a pretty surreal experiencing for me as I've never tuned anything this powerful nor anything that revs this high! Alex said I could safely bring the rev limiter to 8600rpm if I wanted to (which I did lol).
Mods:
  • 3.5" Turbo back with 5" body Venom 100 Cell Cat, 2x Mufflers, Gate plumbed back
  • Generic built RB25DET NEO motor (CP Pistons, Manley Rods, Nitto rings, ACL bearings, ARP dis dat, etc.)
  • Spool billet oil pump gears Nitto Oil Pump
  • Tomei 260/9.15 Poncams Kelford 264/272 244-B
  • HDi Hybrid 76mm eBay FMIC Plazmaman 76mm Pro Series
  • Plazmaman Intake Manifold
  • ATi Balancer
Below is the log (no idea why SAU makes the thumbnails so damn small now. Ignore the oil pressure, it's reading wrong. I suspect the sensor has the right part number printed on it but it's actually a 5 bar sensor (not 10 bar).
Here's a video my mate recorded of me tuning, you can see I'm constantly looking at Alex to see if I need to abort the run. Previously there was a misfire event that sounded like engine knock from where he was standing. I took out the plugs then gapped them down to 0.4mm and it sure did the trick!
  • Like 5
  • 3 weeks later...
R33 GTST
Rb25det Block + Rb26 Crank
Arias 86.5mm Pistons
Eagle H beam rods
ARP 2000 Main studs
Half inch ARP head stud conversion
N1 Nissan Oil pump with Spool gears
Reconditioned head with Kelford Valve springs
1650cc Fuel Injectors
520L fuel pump
Haltech ECU
High mount exhaust manifold
HyperGear ATR43SS-3 Turbocharger
50mm external gate
Tuned at Chequeredtuning
Final result of a responsive 455rwkws @ 26psi maxing out onboard map sensor
294018895_376109891127593_5354837264242904396_n.thumb.jpg.403c055316eaf4d452903284ab6d68d3.jpg
  • Like 1
  • 1 month later...
R33 Rb25det 2.5L engine
CP Pistons
Spool I beams
Stock crankshaft
Spline drive oil pump with billet gears
Arp2000 headstuds
Athena headgasket
Performance valve springs
Stock cams
2400cc Fuel Injectors
2x 520L fuel pump
Rb26 inlet manifold and itbs
Crg twin scroll t4 manifold single 50mm turbosmart gate
Haltech ECU
HyperGear ATR45SS2-RB26 Turbocharger in T4 .82 rear
All work done and tuned by CPG
Final result of 635rwkws / 754rwkws @ 37psi with Nos.
E85 fuel
  • Like 3
  • 2 months later...
R33 GTST Series 1.5
Rb25det Engine:
CP pistons
Spool Con-rods
Kelford 262 / 272 Cams
APR head studs
ID 1650 injectors
2x Walbro 460L Pump
GTR Coilpack upgrade
HyperGear ATR43SS2 Turbocharger
6 boost high mount manifold
Greddy Forward facing plenum with 3 inches throttle body
PWR 600x300x81mm intercooler
3.5 inches stainless turbo back exhaust
50mm Turbosmart gate plumbed back
Haltech Plug-in ECU
Tuned at Chequered tuning
Still have boost control issues to sort, making 400rwkws @ 20psi so far.
enginebay2.thumb.jpg.4861a62f96b3706464980df9df4e26f9.jpgcarondyno.thumb.jpg.5438f612ce6518ab2e6ac613a8b56716.jpg400rwkw.thumb.jpg.34fb54b6fa78dfbfd057b5edd665d721.jpgboost.thumb.jpg.221d7f56a9e8c8b1d57c6a14c9b2604b.jpg
Edited by hypergear
  • Like 1
  • 3 weeks later...
R34 GTT
Factory Rb25det Neo Engine:
ID 1000 injectors
Walbro 460L Pump
HyperGear ATR43SS2 internally gated Turbocharger (2022 June release)
Plazamaman Forward facing plenum
Plazamaman 600x300x76mm intercooler
3 inches stainless turbo back exhaust
Link ECU
Tuned at Chequered tuning Work done at CPG.
Final result of a responsive 346rwkws @ 22psi on E85 fuel so far. Boost held perfectly till red line with plenty of power throughout rev range
318599580_5791546430965619_2613132159764501821_n.thumb.jpg.fd9638a7f317905167e11e9c0b88caaa.jpg
317999160_1200705453852754_1318106964589292279_n.thumb.jpg.93e494986a860f45c8ba1a86e97c2e55.jpg
318292315_1806411269715570_602202984049436119_n.thumb.jpg.38ebdd5d3f31fe542aa4ebcfb8f95c4d.jpg
  • Like 3
  • 2 months later...
R32 GTST Manual
Rb25det Engine
Cp pistons
Spool rods
Cam tech 264 cams. 0 , 0 on Cams gears, No VCT
Hypergear ATR43SS3 turbocharger in T3 .63 rear
Freedy intake
6 Boost T3 Single entry exhaust manifold
Valve springs
1650cc injector
Haltech ecu
389rwkws @ 20psi, Full boost @ 4000RPM.
Pump 98 / Ron 93 fuel. NO E85 this time.
331649005_2126697534194726_5116472742497761640_n.thumb.jpg.09f86193a5cbb597d074439c059549a0.jpg
331812784_1206937897375212_6998443198651292934_n.thumb.jpg.261aac1f59dc4c65e26b5a34993c3088.jpg
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
