Stock rb25 det neo.( BP Ultimate)
Power FC.
HKS Gtrs - 15 psi.
Nismo 480cc injectors.
HKS fmic type s.
HKS extension and front pipes hiflow cat trust PE 2.
Tomei fuel pump.
Splitfires.
Greddy profec B.
228.9 kw @ the wheels on 15 psi.
Responsive setup, lag is not an issue. Gtrs is a beautiful turbo on an rb25 :thumbsup:
Edited by silverr34gtt
1996 R33 GTS-T
* Garrett GT3540
* 3 inch full exhaust system
* Apexi PowerFC with hand controller
* Turbosmart Eboost Controller
* K&N Air filter
* Front Mount Intercooler
* Wastegate/BOV
* Fuel regulator
* Larger Fuel injector
* Fuel pump
* Z32 AFM
282.6KW@18PSI
post-42905-1192104208_thumb.jpg post-42905-1192104241_thumb.jpg post-42905-1192104278_thumb.jpg
1993 r33 gts-t
T04e garrett turbo
high mount manifold
38mm turbosmart external wastegate
turbotech boost controller ( not all its wrapped up to be)
turbosmart stage 1 BOV
hks FMIC
bosch 040 fuel pump
full 3 1/2 inch exaust
198 rwkw at 14psi (safe tune)
R33 4door factory 5speed manual
rb25
standard high flow turbo
full3inch zorst with HKS split dump pipe
555cc nismo inj
600+300+80mm cooler
Power FC
apexi power intake filter kit
stock bottom end
standard head
15pound made 299.4rwhp
18pound went 320rwhp
dont have scanner to post up sheets but not telling lies
as Matt Sprite at P.I.T.S auto tuned my car and he is very very good.
car currently off the road getting
Garrett 3540 fitted on highmount with 42mm turbosmart gate
custom plenum made with bigger TB.
will have it back by wed will post up sheets of dyno once tuned. post-36101-1192517778_thumb.jpg
  • 3 weeks later...
Thought I would post mine up then!
R33 GTST
Front to back
Big FMIC
Apexi Power Cone thing
Custom made hard pipe off the turbo
Nismo 555cc's injectors
Some kind of turbo, looks standard but it aint!
Turbo Elbow with screamer pipe
Full kakimoto exhaust from elbow back
Apexi Power FC
Greddy Profec B spec 2
255lbh Walbro Fuel pump.
@ 0.85 this made 299bhp
@ 1.bar this made 336.3bhp (247kw)
all at the fly.
2nd Time Round
List as Follows:
KKR-480 (Otomoto)
Custom Tuned Length S/S Turbo Manifold
New 3" Exhaust, 3" Cat, No Mufflers
Custom Intake/Fmic Piping, Fmic Tube/Fin
600cc Injectors
Cleaned/Smoothed Plenum/Runners/Throttle Body
Apexi Power Intake
Z32 AFM
Adjustable Exhaust Cam Gear
Apexi Power Fc
Ebc Dual Boost/Scrammble Switch Soon to be upgraded to greddy profec b
Just Jap Tube and Fin Pressure drop from Just Jap Kit (Soon to be upgraded to Otomoto 5" Core)
Cars Tuned got 258rwkws Unique Autosports Tune but that was on 91ron Standard unleaded Petrol Little to no Timing at all
Had to earth out walbro fuel pump (max voltage) plus problems with walbro not keeping pressure up, evident on dyno. Must admitt is a clean smooth powerline. Runs 20psi but drops to 16psi due to walbro.
Lol Didnt get what i WAS expecting from the KKR-480 :w00t:, KKR 480 is really responsive on the rb25 comes on boost at 3000rpm full boost at 4400 rpm did change fuel pump now holds 20psi all the way to redline which is great, got 275/18 and even at 100klms or so 3rd spins lol satified me for 1 day.
3rd Time
So now i have the kkr-560 but its been modified/machined housings so should see close to if not over 300rwkws easily, couple of weeks and we will find out. But ill spend the money this time on 98octane fuel lol
Boost comes on later around 3300rrpm and now i have serious problems with fuel on lappy drops to 10psi almost soon as it hits fullboost (Thats with a brand new walbro 500hp pump), will get bigger/better pump (bosch 044) also some Tomei poncams amd maybe nos to get this big suckers of a turbo spoolin up 1000rpms more or so.
Will see closer to 330rws+ without nos thanks to Pulse Racing at Menai!
Edited by INFRNT
Update - new figures
R33 S1 GTS-t
rebuilt motor
fully balanced bottom end
CP forged pistons
k&n pod filter with CAI
3.5" turbo back exhaust + high flow cat
front mount intercooler
bleed valve boost controller
bosch 040 fuel pump
apex power fc
nismo fuel pressure reg
Z32 air flow meter + tomei plug
hiflowed turbo with VG30 exhaust housing
241.6kw
ill add the dyno link into my sig when i upload it
r33 gtst series 1
stock motor
XTR to4e highflow
denso 800cc injectors
trust drag spec 110mm fmic
split dump into 3" front pipe and 3.5" hks cat back
apexi power intake
walbro 600hp fuel pump
blitz dual sbc boost controller
z32 afm
power fc
252.9rwkw on 1.1bar
Edited by scarface
1994 series 1
Power fc
Stock turbo
Split dump pipe
Hi flow cat
3" exhaust
Front mount intercooler
GTR fuel pump
Nismo fuel reg
Stock injectors
Tuned by Hitman tuning in penrith
Oil filter relocator
222kw at the wheels on 12 psi
1993 R33 GTST
Stock Turbo with some home mods
Stock ECU, fuel pump, injectors,ignition coils
Spilt dump....over 20kw improvement from that!
3 inch exhaust, Hiflow cat, Nismo muffler.. very quiet!
Turbosmart boost controller
Adjustable Exhaust cam gear set at -2deg.
Hybrid front mount Intercooler 800x600x75
Iridium Spark plugs at 0.8mm
K&N Panel Filter
Modified air intake hose to Turbo
Valvoline Syn Power motor oil
Tuned on Shell V power
211rkw at 10psi CO 10.8
510Nm
caltex vortex 98.
3" exhaust
bosch 040
nismo fpr (stock pressure)
on 8psi.
monkey warehouse fmic
stock sedate tune
what u are seeing is a stock r33 with the 'common mods' with no tuning done.
253.8rwhp
Main mods are:
Nismo fuel pump
Full exhaust
Custom Garrett turbo - full boost by 3.1 k
z32 AFM
Blitz FMIC
AVC-R
Power FC
Radiator upgrade
Nismo 555cc injectors
Tomei Cams
Splitfires
Stock internals
Made 295 rwkw at 17 psi
Clutch starting to slip though (on road, was OK for dyno run) :teehee: so time for another upgrade - not making excuses though, very happy with the results as usual
Car: 1989 cefiro
Engine: rb25/rb26 hybrid
Power: 580whp 434ft/lbs TQ @ 1.2bar C16 gas
Performance Mods:87.25mm wiseco forgies 9.8:1, egale H beam RB26 rods, acl bearings, N1 oilpump, R32GTR crank:with custom collar, block line bored, and extra oiling for 26 crank, head quench removed, three angle valave job, hks 272 dur 8.5 lift cammies, hks springs & retainers, Tomei adj cam gears, tomei 2mm head gasket, ARP head studs, GReddy TD06H-25G 16cm turbine, GReddy SS exhaust mani, GReddy GT 50mm wastegate, 555cc injects, rb26 power fc de-jetro, Splitfire coil packs, GReddy intake Mani with Q45 TB, nismo intank fuel pump, bosch inline fuel pump, nismo fpr, power enterprise timing belt...etc...
Dynoed:UNNATURAL INC. Portland, Oregon, USA
When: NOV 12 2008
Mode:awesome
Edited by cefirosliderRB2.7
r33 gtst
split dump pipe
apexi front pipe
xforce cat back with xforce high flow cat
stock turbo at 12psi on GFB bleed valve
stock computer with SAFC2
Apexi power pod with custom heat shield
walbro 550hp fuel pump
npc ceramic 5 puck clutch
red line old tune, blue new tune
290rwhp or 216rwkw
Edited by Pal
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
