  • Replies 125
Very different setup now Ken.
I wont start on Autonics faults but they sure have their share.
Did i mention Wolf has WA fastest 2 SR20s? and RB26.
Did I mention that the highest street hp ( Leewah) GTR in Oz runs Autronics and the highest Hp at Summernats did too...
If the wolf has a very different setup now then why isn't it mentioned on the website or info made avaliable to tuners. Once again I ask why the info is kept so *inhouse* when by sharing it around, it will benefit the product and the yourself as the WA agent.
Cheers
Ken
gtrken isnt the first time i have heard that the wolf rot idle is "fake"....
i have only HEARD i dont know so dont take this as fact.
so ken, what your saying is wolf only lowers and ups the revs to simulate rotational idle...it doesnt actually drop a cylinder??
people argue that it still cools the engine...but its hardly the point...
sounds good, but what about the people that actually need to cool their engine faster....
When you are sick of Rotational idle its nice to have real Idle control with valve openings for cranking and post start idle up and anti stall on decel. fast idle cold etc and only the PFC an Wolf do this, autronic is a very basic voltage based system so most shops only set idle with a srew driver.
Guess what we do cut injectors on rotational idle.
If Kym hates his Wolf we can plug the Nissan ECU in and send him to get something else.
Most shops have in house only secrets.
question for both ken and steve;
with both pfc and wolf can u buy addons for example antilag and have it hook up with the ecu and have both run right?
(by addons i mean, something not made by wolf or apexi, just a standalone type controller for antilag etc?)
cheers mike
No huge plans really - about 350rwhp is all :) Wolf is decided as Steve said :)
Pro's i've seen for Wolf that benefit me:
* No need to buy bigger injectors due to wolf's injection method
* No need for new MAFs cos wolf can use MAP
* Rotational Idle (wank factor)
* Antilag capability
* Laptop Tuneable
* Renowned good results
* Use Wolf Boost Control - Sell EBC
PowerFC Benefits for me:
* Wider range of Tuners
* Renowned good results also
* Cheaper price
* Easier Plug'n'Pray operation
Both have great features really, and it was a hard decision. I don't care for "This ECU is being used in the fastest SR/CA/RB in australia" Because mine is strictly road use :D
As Gav said - He chose the wolf due to the good results previously seen with it, and no doubt I will see good results too :)
Now comes the hard part - What turbo choice for good response with about 350rwhp?
I know a few people have awesome results with a T04 Hyrbid something-or-rather....
Thanks for the good/bad points guys, thankfully not too much bitching eh? :)
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
