goodbye to a good car..
Guest Boxhead
ok well im sorry to say it, but today was the start of saying good bye to my car, its been good to me over the time i was in posesion... ummm yeah what can i say, it was slow, but sure... so ohwell i still have some good pics, on my camera which i cant transfer yet.. dAVE will the pictures and well yeah... i think all i can say is lucky occupants including myself can talk about it now...
https://www.sau.com.au/forums/topic/5681-goodbye-to-a-good-car/
  • Replies 54
no time for crying... he has to go shopping for a new car now!!! (*cough* you know u want a 33 *cough* )... whilst he nurses his injuries.
also, tomoz I will get some photos with him when we visit it. Was at the hospital when they flipped it over and towed it away, so we didnt get any photos of the crushed roof, but I hear it looks even worse when its up the right way.. so stay tuned.
Guest Boxhead
hey, no cryin, prolly will happen when i go to bed.. as erin said, yeah i only just got it back etc, remember i wasnt driving so can you stop askin what i did..
yeah well anyway.. everyone is ok, i have some seatbelt burns..
all i can say is, if anyone ever wants me to endorse seatbelts, im a call away... just ask dave what he saw as car flippin...
ohwell.. no r33 for me dave, no whale! hopefully another r32..
im just dissapointed about me makin teh car orginal and all... like.. i dunno, the blue, teh kit..... sh*t happens....
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
