Hi Guys
I have a friend who imports short shift kits (enhanced Cs copy) and I can get some good deals from him if I buy in bulk. This is the going rate
buy 5 for $145 each
buy 10 for $130 each
buy 15 for $120 each
buy more than 20 probably $110 each but we will see if there are that many takers.
Postage is usually $13
Here is the list of short shift kits I can get
R33
R32
Silvia/180sx
s14/200sx
If you guys are interested pm me or email me or reply to this thread.
Over the next few days/week I will see how many people are interested and let you all know what the cost will be. If everthing goes good I will then need the money from the buyers and I will get the parts and send them out to you guys. If everyone pays up quickly the buyers should get their strut brace within 7 days.
https://www.sau.com.au/forums/topic/57182-short-shift-r33-r32-silvia-180sx/
  • Replies 69
Interested in one for an R32 GTR.
A question: on the website listed at the bottom of your post it shows the price for a short shifter for an R32 or R33 as $145 - is that for one kit ?? It's just that I would have thought the price for 5 would be less than the price for one.....
If I bought all 5 myself then I can sell them for $145 each. Which I was doing a few weeks ago. But I decided make life a little easier and hopefully I can make the prices cheaper for you guys by having more money up front and buying in bulk. So this is where the group buy comes in.
I should really change my website. Thanks dude...
with the short shifters is the gear nob part removeable because i have a razzo gear nob that i would prefert to attach to the top as opposed to the silver bulb that it has in the pics. so it it possible to unscrew the silver one and is there a standard thread to put my old one onto?
Yes gear knob is removable. I was able to put my genuine skyline knob back on
Seriously it is really easy to install. Instructions shows you what to do. If you get into trouble then email me...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
