380hp
and its making 306rwhp on 18psi with a lack of timing
tuner said it will easily make 320+ on only 18psi, just need to fix the miss :)
Will be interesting to see what you can get out of then. If you are able to get 250-260rwkws (340-350rwhp) out of it and still have good bottom end...then yeh the theory with the manifold will be taking a beating. :D
Hi Guys
My HKS cast manifold is of at afe being flow tested at the moment will post results when I get it back though he still recons that will be a couple of weeks 4 months of the road and counting damn it
Cheers Peter
just had some more work done on my 20 this week
put an external gate out the back of my td-06 17c which was internal gate, big new breather tank set up and bigger pod, and profec b spec2
went 357.5rwhp at 19psi
on standard exh mani
and no head or bottom end work for now
i did not think an rb20 was capable of this
Ah, bored in a hotel room waiting for this afternoons drinking session, er i mean Hurling Grand Final...so
TD06-20G
Here is the Mitsubishi version of my compressor , then the 17C
TD06-17C
Are you sure you have a TD06-17C. You seem to be making more power then the compressor map suggests possible. Even allowing for differences in MHI vs Trust turbos
yeh the 17c has a rating of 400hp in internal form, i made 280hp before converting also at 19psi and full boost was at around 4000rpm. but the tune wasnt as good.
mods are:
gts4rb20
gtr injectors
ems stinger
td06 with tial copy gate
cooler, big breather
pretty small budget, biggest gains were had with opening up the back of the turbo and fitting a big pod. all of this is in an s13 silvia aswell, will post graph soon
you made 77rwhp from a tune and changing from blocking the actuator and controlling boost via a bigger external wastegate, at the same boost?
if so, im going to get gate...
Edited by Cerbera
from what research ive done on line it seems that using an external gate and routing it out to atmosphere will actualy allow for hp gains.
i know some one on a supra forum was tired of the noise of the external gate and rerouted it and found on the dyno he had lost 30whp simply by rerouteing the gate into the exhaust.
and its not unusual to gain silly hp via a proper tune, local shop here fuel tuned a blown mustang and made 550whp, not shabby, but when they went back and did some ignition tuning it jumped to a hair over 700whp.
For all you boat anchor lovers
http://www.skylinesaustralia.com/forums/in...howtopic=103095
Ha ha ha nothing wrong with the old boat anchor :( , thanks mate :P
hey i just have a quick question, and im hoping someone can answer for me, i have a bosch 019 intank pump at the moment, which i am maxing out, can someone tell me the next 2 sized up bosch pump that are intank please? plus flow rates aswell if possible. i want an intank pump, not external.
thanks in advance
chris
Meh dont know unless i look up some info i have at home...but my 2c, dont need to
Get a new Bosch 040. They are cheap new, and flow more then a GTR pump, and fit easilt in the std cradle with a 30min tweak.Installation is a DIY 90 min job. If you want to set up a fulltime power supply and relay it takes a bit longer :)
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
