380hp
and its making 306rwhp on 18psi with a lack of timing
tuner said it will easily make 320+ on only 18psi, just need to fix the miss :)
Will be interesting to see what you can get out of then. If you are able to get 250-260rwkws (340-350rwhp) out of it and still have good bottom end...then yeh the theory with the manifold will be taking a beating. :D
Hi Guys
My HKS cast manifold is of at afe being flow tested at the moment will post results when I get it back though he still recons that will be a couple of weeks 4 months of the road and counting damn it
Cheers Peter
just had some more work done on my 20 this week
put an external gate out the back of my td-06 17c which was internal gate, big new breather tank set up and bigger pod, and profec b spec2
went 357.5rwhp at 19psi
on standard exh mani
and no head or bottom end work for now
i did not think an rb20 was capable of this
Ah, bored in a hotel room waiting for this afternoons drinking session, er i mean Hurling Grand Final...so
TD06-20G
Here is the Mitsubishi version of my compressor , then the 17C
TD06-17C
Are you sure you have a TD06-17C. You seem to be making more power then the compressor map suggests possible. Even allowing for differences in MHI vs Trust turbos
yeh the 17c has a rating of 400hp in internal form, i made 280hp before converting also at 19psi and full boost was at around 4000rpm. but the tune wasnt as good.
mods are:
gts4rb20
gtr injectors
ems stinger
td06 with tial copy gate
cooler, big breather
pretty small budget, biggest gains were had with opening up the back of the turbo and fitting a big pod. all of this is in an s13 silvia aswell, will post graph soon
you made 77rwhp from a tune and changing from blocking the actuator and controlling boost via a bigger external wastegate, at the same boost?
if so, im going to get gate...
Edited by Cerbera
from what research ive done on line it seems that using an external gate and routing it out to atmosphere will actualy allow for hp gains.
i know some one on a supra forum was tired of the noise of the external gate and rerouted it and found on the dyno he had lost 30whp simply by rerouteing the gate into the exhaust.
and its not unusual to gain silly hp via a proper tune, local shop here fuel tuned a blown mustang and made 550whp, not shabby, but when they went back and did some ignition tuning it jumped to a hair over 700whp.
For all you boat anchor lovers
http://www.skylinesaustralia.com/forums/in...howtopic=103095
Ha ha ha nothing wrong with the old boat anchor :( , thanks mate :P
hey i just have a quick question, and im hoping someone can answer for me, i have a bosch 019 intank pump at the moment, which i am maxing out, can someone tell me the next 2 sized up bosch pump that are intank please? plus flow rates aswell if possible. i want an intank pump, not external.
thanks in advance
chris
Meh dont know unless i look up some info i have at home...but my 2c, dont need to
Get a new Bosch 040. They are cheap new, and flow more then a GTR pump, and fit easilt in the std cradle with a 30min tweak.Installation is a DIY 90 min job. If you want to set up a fulltime power supply and relay it takes a bit longer :)
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
