another update on mine
well ive now sold the trust td06 a couple months ago because i wanted to try something else, i managed to pic up a garret GT3040R with a ceramic coated .63 rear housing, xspower stainless high mount manifold and a new tial 38mm gate with .9 spring.
while it was off the road and in bits i thought it was about time i dropped some cams into it, i picked up a set of hks 264 9.0 (or 9.1 im not to sure as there an older version of the cam with no lift spec stamped on) i also put adjustable gears on them
on its current tune its made 346rwp @22psi, not the 400 it used to make but what i find impressive is the power comes on so much earlier now, it feels faster to drive than when it had 400, no dyno sheet of it as i forget to grab it!
Your engine bay look mint AD4M! Nice work man.
Just got a question for you RB20 freaks;
Just wondering what power is expected from my standard RB20, I'm getting it tuned very soon with the following mods;
Apexi Power FC (AP Engineering RB20)
Z32 AFM
BNR32 injectors
Bosch 040 intank f/pump
Blitz return flow intercooler
HKS cast low mount manifold (Ex-gate port at the top)
HKS T04e (unsure of size)
HKS Ex-gate
Standard air box with CAI
Motor is completely stock, no internal work or anything just the bolt on upgrades.
Don't know the exact specs on the turbo as it hasn't arrived from Japan just yet, only bought the kit because it previously came of an RB20 in Japan and is all straight bolt on.
But just wanted to get a rough idea of what is expected.
Thanks.
cheers Abu, alot of effort went into it this time round :)
Yeah it seems like it man, looks quality!
with your setup i have a mate here with pretty much the same setup, except he's running a microtech ecu
last tune i think it made a safe 310 rwhp @18psi
Ah very nice, thats about what I want it to make at around 18-19psi would be the most I would push it.
Maybe after the tune I might consider some cams for some extra power and response.
Did your cams make much difference or you didn't tune it before and after?
i would have liked to do the cams on the td06 setup for comparison sakes but nah it was all done in one hit with the new turbo setup.
another bonus is the overlap at idle :D sounds soo tough now haha
but the cams have made the throttle response alot better down low in the revs while its off boost i feel
Got my car started tonight.
I have a few issues that need sorting out but atleast the bastard runs after 16 months of it being off the road. Oil pressure is good, just needs the ECU tweaked and a few little bits and pieces, so In around a month or two it should be on the track :D
Mods are (for those who dont know)
RB20DET - totally stock
Trust TD06 L2
Emanage Ultimate
550cc sard injectors
Z32 afm
Bosch 023 in tank pump
supporting mods etc
I will run around 1.2bar through it to start and go from there :(
Looking forward to see what the L2 does Wheezy! :(
AD4Mm looks a treat mate. congrats. One thing, when you get bored throw the std cams back in and give it a quick re-tune with attention to the cam gears. I suspect you will make more top end on less boost with a touch more response. :)
LOL, but this is not a guarantee....i ran very similar cams and went backwards a touch, required more boost to make the same power and lost a little response :D
Z32 AFM
BNR32 injectors
HKS Ex-gate
Would it be worth using adjustable CAM gears with the above?
ABSOLUTELY!!!!!!!!!!!!!
The secret is spending the money in the tuning to get the thing on song. My first tuner said they lost power when they played with the cam timing, ended up leaving them at 0. My current tuner has them cocked around to whatever setting and there was a marked improvement. Interesting to see if others have noticed the same when they have spent the money on tuning. Cant wait for Interloper to get some on his GT-RS.
(Yes i know Interloper...i may use your pipe and modify my current one for you :D )
Maybe someone has some info on cam gears on standard rb20 ? I plan to use t3/t4 turbo(compressor a/r 0.5, turbine a/r - 0.63), external wastegate.
I was thinking about 220+ rwkw could be possible with that turbo. Would I benefit from cam gears on my setup ? As I will be doing all the tuning myself, how should I adjust the cam gears to get more mid-range ? I'm not that keen on top end. Wanna save the baby rb20det for a little longer. God knows how much more health it has, and redlining it only makes its life shorter.
adam, in the back of your bay where did you get those red heat covers that are on your silicon hoses? do they stop the heat from getting in that much? she's looking real good btw
lol, i was beginning to think that you had forgotten all about mine :banana:
and those cam gears are going on the HKS 2510 first!
I think i really need to invest some time in more tuning for mine...my cam gears were just set to +3 IN -6 EX and just tuned from there...Interloper...are you running a remap? would be really interested in seeing your results...if i get mine done i'll post it up too...cheers...
cheers for the kind words guys
Roy it would be good to try that to see where exactly in the rev range the cams are working there magic, but i really cant be stuffed pulling it appart AGAIN haha.
Koree you can get it from Go Gear in osbourne park, I've put it over all the water lines,oil feed and oil drain aswell (it comes in diferent size diametre) I used it more as a safety thing then anything.
hows the old girl coming along mate?
Hey guys,
i am getting my Cefiro tuned this saturday, and was wondering if anyone had any idea (or guesses) of what i'll get?
Specs
RB24 - GTR crank / rods / Tomei pistons
Tomei 1.5 HG
Tomei adjustable cam gears (set at 0 still)
Garrett GT3076r IW - 0.6 front, 56trim, .63 exhaust housing - wastegate ported and larger flap installed.
Dmax low mount stainless manifold
AM performance stainless, custom screamer pipe
3" straight pipe to twin flutes (no cat / mufflers)
Apexi Power FC (AP Engineering)
444cc injectors
nismo fuel pressure regulator
walbro intank fuel pump.
Gizmo EBC
I'm wanting to pump 1.5 Bar into it and see how it goes.
what you reackon? I hope i'm not disappointe lol...
i reckon +3 IN -6 EX is about right given thats pretty much what Roy's using.
The remaps on the GT-RS, but the PFC is running the 2510 and thats where the cam gears will go :glare:
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
