Jap Import Parts
I attached the image of the only thing I found, nothing to do with ohms in the manual only torque values etc. However, being they are so close to each other I am almost certain they are good. Tomorrow I will test the spark plugs while I am there. and look at the ECU connections.
Hi Gents. Do u know what 18rim will fit under R32 GTST with no modification of current setup I have. I have buddy Club P1 17x8 on front and 17x9 rears and they fit well. Will an 18x9 on 35 off set with 235 tyres up front fit? ON the Rears i can run the rim size n fit 255 or 245? or i got option to get 18x9.5 on 35+ Offset n 265? CHeers
And, when measuring and getting <2 ohms, perhaps chose the next larger range than that, rather than something with a k in it!
'sif the ARB does anything on an Astra anyway!
You want the service manual that Josh references so you know what to measure, and how it needs to be connected doing the measurement, AND the expected value.
